After a Samba problem (password request on a windows free account), I no longer have access to my files !!!
1- I reboot the Pi … since it cleans the file system … (fsck)
SEVERAL TIMES, I reboot, I put out, I turn back … ON, OFF etc
NO ! don’t work !
2- I control another computer: no problem sharing folder !
it is the Pi that fails
3- I clean the key with GParted Linux: it works !!!
(after boot “systemrescuecd” disk on my PC)
No Comment
Moral: the slightest problem unresolved at boot, so try GParted and Check / Repair
PS : don’t explain me that it’s impossible : it is !
and no, I’m not a spammer or a flooder, I juste want to help
We’ve been through this before.
This really sounds like system instability on your side. No one else seems to report this.
If it’s working for you – then great, but it’s not gospel, and I’m telling you for a fact that:
- OSMC scans for file system corruption and will attempt to repair it on boot
- Repeated file system corruption is often indicative of some faulty hardware (an insufficient PSU, or a faulty / incompatible SD card).
- The Samba changes which require a password are not caused by filesystem corruption. This is a change in the default behaviour introduced by the Samba maintainers to improve security. If you search the forum you will find more info on this.
