Hello guys i need your help over here.
I wrote a little script which should start my server when it osmc is booting.
So the problem is its not working with systemd but if i execute manually its working fine.
Need the your eyes i cant solve the problem.
[Unit]
Description=wol deamon
After=syslog.target network-online.target
Before=multi-user.target mediacenter.service
[Service]
User=osmc
Group=osmc
Type=oneshot
ExecStart=/usr/bin/bash /home/osmc/wol.sh
TimeoutStopSec=30
[Install]
WantedBy=multi-user.target
Check the unit is enabled
Check the status of the unit
Wow instant answer.
Do you mean
systemctl enable wol.service
if yes i did it
here is the status from the service
osmc@osmc:~$ systemctl status wol.service
* wol.service - wol deamon
Loaded: loaded (/etc/systemd/system/wol.service; enabled)
Active: activating (start) since Fri 2017-01-20 20:42:34 CET; 46s ago
Main PID: 344 (wol.sh)
CGroup: /system.slice/wol.service
|-344 /bin/bash /home/osmc/wol.sh
`-447 ping -c 1 192.168.222.5
it seems like its starting but its not working.
Some issues.
Your initial systemd unit seemed to show Python, now it shows bash.
Your status call shows /bin/bash but your unit shows /usr/bin/bash. Check you are calling the correct interpreter and check your path
yes the first one was the wrong one i tryed it first with a python script and it worked so i moved to the bash script which is the one for wol.
but its working now thank you for your tipps. it was a path error in the wol script itself and i deleted /usr/ from the service so its working now ty again.
the working service:
[Unit]
[Service]
User=osmc
Group=osmc
Type=oneshot
ExecStart=/bin/bash /home/osmc/wol.sh
TimeoutStopSec=30
[Install]
