[Deprecated] [TESTING] Bluetooth audio streaming (A2DP)
June '16 update is breaking my usb sound output.
I’updated to the latest june '16 update, since then, der is no audio output. I’m using a USB soundcard.
when uninstalling A2DP like this:
sudo dpkg -r pulseaudio-module-bluetooth
sudo dpkg -r pulseaudio-module-zeroconf
sudo dpkg -P pulseaudio
sudo dpkg -r a2dp-app-osmc
it is working again,but without A2DP :wink:
after reinstalling A2DP there is still no sound output, only without pulse audio it’s working
any ideas what can be broken?
I guess it will be something like this …
xbmc.executeJSONRPC(‘{“jsonrpc”:“2.0”,“method”:“Settings.SetSettingValue”, “params”:{“setting”:“audiooutput.audiodevice”,“value”:“%s”},“id”:1}’ % dev)
We’ve not changed anything with Bluetooth audio in this update
From this post:
I guess it will be something like this:
curl -v -H “Content-type: application/json” -X POST -d ‘{“jsonrpc”:“2.0”,“method”:“Settings.SetSettingValue”, “params”:{“setting”:“audiooutput.audiodevice”,“value”:“ALSA:hdmi:CARD=NVidia,DEV=1”},“id”:1}’ http://localhost:9191/jsonrpc
ok, after reinstalling like shown above with the USB soundcard attached, sound output is working with A2DP installed.
But now there is no audio output from streamed music (streamed from iPhone)
I’ll keep on searching…
Nope. It doesn’t seem to be a config setting that can be changed with JSON-RPC :frowning:
Hi anbodearg again
Do you have to adjust the audio offset to about 300ms on your setup. Mine has roughly 300ms delay on my soundbar using BT dongle.
I’m using audio streaming radio from another OSMC. If there is a delay, it is not noticeable.
I have tried a couple of YouTube videos and the audio and video seem pretty much in sync.
update:
Everything working (more stable) now with new RPI 5.1V/2.5A psu, onboard WiFi, BT dongle.
I powered-on BT speaker this morning, and audio was working :slight_smile:
This means that the BT pairing, BT connection, Audio Output to BT speaker settings are persisting,
and not getting forgotten.
At 6am every morning, OSMC is configured to reboot (cron). I think this is making it a bit more reliable.
I still seem to need the odd reboot, but definitely not as often as before (it was almost every single day).
Thanks.
Best regards,
Niall.
Update:
BT audio streaming working most of the time.
Sometimes I need to reboot RPI3, and reset the Audio output.
The BT pairing seems to be much more reliable than before.
Sometimes I need to power-off RPI3 in order to get the BT audio streaming to work again.
Maybe 1 day every 7 days.
Not as often as previously - but still OSMC is losing the Audio output every few days.
Thanks.
Best regards,
Niall.
In three months, this thread will be a year old. Are we actually still “TESTING” this functionality?
Yep
I’d say yes. There’s quite a lot of work to do before this can be considered even beta quality. If you have some patches or suggestions, let me know.
Works right out of the box, thank you!!! :heart:
I have successfully installed using your method and I can able to pair my speakers. But when I restarted my pi 3 (OSMC) I am not getting any sound on my blue tooth speaker even it says my speakers are connected. I am using latest OSMC. And also sometime I can play mp3 fine but when I play movie, I cant get voice thro’ my speakers.
What should I do to resolve my issue?
ps: I just reinstall OSMC and did the same process, now I can connect to bluetooth speakers but no sound even after selecting Alsa…sound from the OSMC menu.
Bluetooth audio is not routed through ALSA, it goes through PA.
update:
Worked solidly for 5 days. Streaming audio (from another OSMC) to
Bose BT speaker - which powers-off at night. I turn it on again in the morning.
But when it stops working, I need to power-off RPI, and then sometimes reboot again.
The BT connect/pairing seems to persist.
But the Audio output gets forgotten, and it takes a few goes to get it working again.
Once it’s working, it keeps going for a few days.
A big improvement from around a year ago.
But still something not right.
Are there any errors or logs which I could provide?
Thanks.
Best regards,
Niall.
That’s why it’s still in testing. There are still a few things for us to improve.
On Pi, I think the sink is getting locked. Do the following commands restore audio without requiring a system reboot?
sudo rmmod snd-bcm2835
sudo modprobe snd-bcm2835
I know that @fzinken had this problem too. I will discuss this with him when I get back and see if I can work out why the sink is getting locked.
Logs when you have problems playing back would be helpful.
Sure, Sam. I’ll try that next time it happens, and I’ll report back.
When the audio drops, and I try restore it by changing to HDMI, and back again to BT (that used to work), I guess there should be an error somewhere…? (dmesg, maybe?)
Thanks.
Best regards,
Niall.
Tried:
osmc@Kitchen:~$ sudo rmmod snd-bcm2835
rmmod: ERROR: Module snd_bcm2835 is in use
osmc@Kitchen:~$ dmesg -T
[Tue Jul 5 06:01:38 2016] Booting Linux on physical CPU 0x0
[Tue Jul 5 06:01:38 2016] Initializing cgroup subsys cpuset
[Tue Jul 5 06:01:38 2016] Initializing cgroup subsys cpuacct
[Tue Jul 5 06:01:38 2016] Linux version 4.4.13-5-osmc (root@vero2a) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Mon Jun 20 16:34:27 UTC 2016
[Tue Jul 5 06:01:38 2016] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[Tue Jul 5 06:01:38 2016] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[Tue Jul 5 06:01:38 2016] Machine model: Raspberry Pi 3 Model B Rev 1.2
[Tue Jul 5 06:01:38 2016] cma: Reserved 8 MiB at 0x2e400000
[Tue Jul 5 06:01:38 2016] Memory policy: Data cache writealloc
[Tue Jul 5 06:01:38 2016] On node 0 totalpages: 192512
[Tue Jul 5 06:01:38 2016] free_area_init_node: node 0, pgdat 80bd0140, node_mem_map add64000
[Tue Jul 5 06:01:38 2016] Normal zone: 1692 pages used for memmap
[Tue Jul 5 06:01:38 2016] Normal zone: 0 pages reserved
[Tue Jul 5 06:01:38 2016] Normal zone: 192512 pages, LIFO batch:31
[Tue Jul 5 06:01:38 2016] [bcm2709_smp_init_cpus] enter (9660->f3003010)
[Tue Jul 5 06:01:38 2016] [bcm2709_smp_init_cpus] ncores=4
[Tue Jul 5 06:01:38 2016] PERCPU: Embedded 13 pages/cpu @aefaa000 s23552 r8192 d21504 u53248
[Tue Jul 5 06:01:38 2016] pcpu-alloc: s23552 r8192 d21504 u53248 alloc=13*4096
[Tue Jul 5 06:01:38 2016] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[Tue Jul 5 06:01:38 2016] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190820
[Tue Jul 5 06:01:38 2016] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1440 bcm2708_fb.fbheight=900 bcm2709.boardrev=0xa02082 bcm2709.serial=0x9ff3f350 smsc95xx.macaddr=B8:27:EB:F3:F3:50 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[Tue Jul 5 06:01:38 2016] PID hash table entries: 4096 (order: 2, 16384 bytes)
[Tue Jul 5 06:01:38 2016] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[Tue Jul 5 06:01:38 2016] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[Tue Jul 5 06:01:38 2016] Memory: 741072K/770048K available (8006K kernel code, 439K rwdata, 1864K rodata, 1792K init, 764K bss, 20784K reserved, 8192K cma-reserved)
[Tue Jul 5 06:01:38 2016] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xaf800000 - 0xff800000 (1280 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x809abb24 (9871 kB)
.init : 0x809ac000 - 0x80b6c000 (1792 kB)
.data : 0x80b6c000 - 0x80bd9e4c ( 440 kB)
.bss : 0x80bdc000 - 0x80c9b36c ( 765 kB)
[Tue Jul 5 06:01:38 2016] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[Tue Jul 5 06:01:38 2016] Preemptible hierarchical RCU implementation.
[Tue Jul 5 06:01:38 2016] Build-time adjustment of leaf fanout to 32.
[Tue Jul 5 06:01:38 2016] NR_IRQS:16 nr_irqs:16 16
[Tue Jul 5 06:01:38 2016] Architected cp15 timer(s) running at 19.20MHz (phys).
[Tue Jul 5 06:01:38 2016] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[Tue Jul 5 06:01:38 2016] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[Tue Jul 5 06:01:38 2016] Switching to timer-based delay loop, resolution 52ns
[Tue Jul 5 06:01:38 2016] Console: colour dummy device 80x30
[Tue Jul 5 06:01:38 2016] console [tty0] enabled
[Tue Jul 5 06:01:38 2016] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[Tue Jul 5 06:01:38 2016] pid_max: default: 32768 minimum: 301
[Tue Jul 5 06:01:38 2016] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[Tue Jul 5 06:01:38 2016] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[Tue Jul 5 06:01:38 2016] Disabling cpuset control group subsystem
[Tue Jul 5 06:01:38 2016] Initializing cgroup subsys io
[Tue Jul 5 06:01:38 2016] Initializing cgroup subsys memory
[Tue Jul 5 06:01:38 2016] Initializing cgroup subsys devices
[Tue Jul 5 06:01:38 2016] Initializing cgroup subsys freezer
[Tue Jul 5 06:01:38 2016] Initializing cgroup subsys net_cls
[Tue Jul 5 06:01:38 2016] CPU: Testing write buffer coherency: ok
[Tue Jul 5 06:01:38 2016] ftrace: allocating 19426 entries in 57 pages
[Tue Jul 5 06:01:38 2016] CPU0: update cpu_capacity 1024
[Tue Jul 5 06:01:38 2016] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[Tue Jul 5 06:01:38 2016] [bcm2709_smp_prepare_cpus] enter
[Tue Jul 5 06:01:38 2016] Setting up static identity map for 0x8240 - 0x8298
[Tue Jul 5 06:01:38 2016] [bcm2709_boot_secondary] cpu:1 started (0) 17
[Tue Jul 5 06:01:38 2016] [bcm2709_secondary_init] enter cpu:1
[Tue Jul 5 06:01:38 2016] CPU1: update cpu_capacity 1024
[Tue Jul 5 06:01:38 2016] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[Tue Jul 5 06:01:38 2016] [bcm2709_boot_secondary] cpu:2 started (0) 16
[Tue Jul 5 06:01:38 2016] [bcm2709_secondary_init] enter cpu:2
[Tue Jul 5 06:01:38 2016] CPU2: update cpu_capacity 1024
[Tue Jul 5 06:01:38 2016] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[Tue Jul 5 06:01:38 2016] [bcm2709_boot_secondary] cpu:3 started (0) 15
[Tue Jul 5 06:01:38 2016] [bcm2709_secondary_init] enter cpu:3
[Tue Jul 5 06:01:38 2016] CPU3: update cpu_capacity 1024
[Tue Jul 5 06:01:38 2016] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[Tue Jul 5 06:01:38 2016] Brought up 4 CPUs
[Tue Jul 5 06:01:38 2016] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[Tue Jul 5 06:01:38 2016] CPU: All CPU(s) started in HYP mode.
[Tue Jul 5 06:01:38 2016] CPU: Virtualization extensions available.
[Tue Jul 5 06:01:38 2016] devtmpfs: initialized
[Tue Jul 5 06:01:38 2016] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[Tue Jul 5 06:01:38 2016] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[Tue Jul 5 06:01:38 2016] pinctrl core: initialized pinctrl subsystem
[Tue Jul 5 06:01:38 2016] NET: Registered protocol family 16
[Tue Jul 5 06:01:38 2016] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[Tue Jul 5 06:01:38 2016] cpuidle: using governor ladder
[Tue Jul 5 06:01:38 2016] cpuidle: using governor menu
[Tue Jul 5 06:01:38 2016] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[Tue Jul 5 06:01:38 2016] hw-breakpoint: maximum watchpoint size is 8 bytes.
[Tue Jul 5 06:01:38 2016] Serial: AMBA PL011 UART driver
[Tue Jul 5 06:01:38 2016] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[Tue Jul 5 06:01:38 2016] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[Tue Jul 5 06:01:38 2016] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[Tue Jul 5 06:01:38 2016] SCSI subsystem initialized
[Tue Jul 5 06:01:38 2016] usbcore: registered new interface driver usbfs
[Tue Jul 5 06:01:38 2016] usbcore: registered new interface driver hub
[Tue Jul 5 06:01:38 2016] usbcore: registered new device driver usb
[Tue Jul 5 06:01:38 2016] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-06-13 13:25
[Tue Jul 5 06:01:38 2016] clocksource: Switched to clocksource arch_sys_counter
[Tue Jul 5 06:01:38 2016] FS-Cache: Loaded
[Tue Jul 5 06:01:38 2016] CacheFiles: Loaded
[Tue Jul 5 06:01:38 2016] NET: Registered protocol family 2
[Tue Jul 5 06:01:38 2016] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[Tue Jul 5 06:01:38 2016] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[Tue Jul 5 06:01:38 2016] TCP: Hash tables configured (established 8192 bind 8192)
[Tue Jul 5 06:01:38 2016] UDP hash table entries: 512 (order: 2, 16384 bytes)
[Tue Jul 5 06:01:38 2016] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[Tue Jul 5 06:01:38 2016] RPC: Registered named UNIX socket transport module.
[Tue Jul 5 06:01:38 2016] RPC: Registered udp transport module.
[Tue Jul 5 06:01:38 2016] RPC: Registered tcp transport module.
[Tue Jul 5 06:01:38 2016] RPC: Registered tcp NFSv4.1 backchannel transport module.
[Tue Jul 5 06:01:38 2016] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[Tue Jul 5 06:01:38 2016] futex hash table entries: 1024 (order: 4, 65536 bytes)
[Tue Jul 5 06:01:38 2016] audit: initializing netlink subsys (disabled)
[Tue Jul 5 06:01:38 2016] audit: type=2000 audit(0.489:1): initialized
[Tue Jul 5 06:01:38 2016] VFS: Disk quotas dquot_6.6.0
[Tue Jul 5 06:01:38 2016] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[Tue Jul 5 06:01:38 2016] FS-Cache: Netfs ‘nfs’ registered for caching
[Tue Jul 5 06:01:38 2016] NFS: Registering the id_resolver key type
[Tue Jul 5 06:01:38 2016] Key type id_resolver registered
[Tue Jul 5 06:01:38 2016] Key type id_legacy registered
[Tue Jul 5 06:01:38 2016] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[Tue Jul 5 06:01:38 2016] io scheduler noop registered
[Tue Jul 5 06:01:38 2016] io scheduler bfq registered (default)
[Tue Jul 5 06:01:38 2016] BFQ I/O-scheduler version: v7r7
[Tue Jul 5 06:01:38 2016] BCM2708FB: allocated DMA memory ee800000
[Tue Jul 5 06:01:38 2016] BCM2708FB: allocated DMA channel 0 @ f3007000
[Tue Jul 5 06:01:38 2016] Console: switching to colour frame buffer device 180x56
[Tue Jul 5 06:01:39 2016] bcm2835-rng 3f104000.rng: hwrng registered
[Tue Jul 5 06:01:39 2016] vc-cma: Videocore CMA driver
[Tue Jul 5 06:01:39 2016] vc-cma: vc_cma_base = 0x00000000
[Tue Jul 5 06:01:39 2016] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[Tue Jul 5 06:01:39 2016] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[Tue Jul 5 06:01:39 2016] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[Tue Jul 5 06:01:39 2016] brd: module loaded
[Tue Jul 5 06:01:39 2016] loop: module loaded
[Tue Jul 5 06:01:39 2016] vchiq: vchiq_init_state: slot_zero = 0xae880000, is_master = 0
[Tue Jul 5 06:01:39 2016] Loading iSCSI transport class v2.0-870.
[Tue Jul 5 06:01:39 2016] usbcore: registered new interface driver smsc95xx
[Tue Jul 5 06:01:39 2016] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[Tue Jul 5 06:01:39 2016] Core Release: 2.80a
[Tue Jul 5 06:01:39 2016] Setting default values for core params
[Tue Jul 5 06:01:39 2016] Finished setting default values for core params
[Tue Jul 5 06:01:39 2016] Using Buffer DMA mode
[Tue Jul 5 06:01:39 2016] Periodic Transfer Interrupt Enhancement - disabled
[Tue Jul 5 06:01:39 2016] Multiprocessor Interrupt Enhancement - disabled
[Tue Jul 5 06:01:39 2016] OTG VER PARAM: 0, OTG VER FLAG: 0
[Tue Jul 5 06:01:39 2016] Dedicated Tx FIFOs mode
[Tue Jul 5 06:01:39 2016] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xae814000 dma = 0xee814000 len=9024
[Tue Jul 5 06:01:39 2016] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[Tue Jul 5 06:01:39 2016] dwc_otg: Microframe scheduler enabled
[Tue Jul 5 06:01:39 2016] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x8057bd48
[Tue Jul 5 06:01:39 2016] WARN::hcd_init_fiq:414: FIQ ASM at 0x8057c0b8 length 36
[Tue Jul 5 06:01:39 2016] WARN::hcd_init_fiq:439: MPHI regs_base at 0xafb1e000
[Tue Jul 5 06:01:39 2016] dwc_otg 3f980000.usb: DWC OTG Controller
[Tue Jul 5 06:01:39 2016] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[Tue Jul 5 06:01:39 2016] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[Tue Jul 5 06:01:39 2016] Init: Port Power? op_state=1
[Tue Jul 5 06:01:39 2016] Init: Power Port (0)
[Tue Jul 5 06:01:39 2016] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[Tue Jul 5 06:01:39 2016] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Tue Jul 5 06:01:39 2016] usb usb1: Product: DWC OTG Controller
[Tue Jul 5 06:01:39 2016] usb usb1: Manufacturer: Linux 4.4.13-5-osmc dwc_otg_hcd
[Tue Jul 5 06:01:39 2016] usb usb1: SerialNumber: 3f980000.usb
[Tue Jul 5 06:01:39 2016] hub 1-0:1.0: USB hub found
[Tue Jul 5 06:01:39 2016] hub 1-0:1.0: 1 port detected
[Tue Jul 5 06:01:39 2016] dwc_otg: FIQ enabled
[Tue Jul 5 06:01:39 2016] dwc_otg: NAK holdoff enabled
[Tue Jul 5 06:01:39 2016] dwc_otg: FIQ split-transaction FSM enabled
[Tue Jul 5 06:01:39 2016] Module dwc_common_port init
[Tue Jul 5 06:01:39 2016] usbcore: registered new interface driver usb-storage
[Tue Jul 5 06:01:39 2016] mousedev: PS/2 mouse device common for all mice
[Tue Jul 5 06:01:39 2016] usbcore: registered new interface driver usbtouchscreen
[Tue Jul 5 06:01:39 2016] bcm2835-cpufreq: min=600000 max=1200000
[Tue Jul 5 06:01:39 2016] sdhci: Secure Digital Host Controller Interface driver
[Tue Jul 5 06:01:39 2016] sdhci: Copyright(c) Pierre Ossman
[Tue Jul 5 06:01:39 2016] sdhost: log_buf @ ae813000 (ee813000)
[Tue Jul 5 06:01:39 2016] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[Tue Jul 5 06:01:40 2016] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[Tue Jul 5 06:01:40 2016] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[Tue Jul 5 06:01:40 2016] mmc0: host does not support reading read-only switch, assuming write-enable
[Tue Jul 5 06:01:40 2016] mmc0: new high speed SDHC card at address 1234
[Tue Jul 5 06:01:40 2016] mmcblk0: mmc0:1234 SA08G 7.25 GiB
[Tue Jul 5 06:01:40 2016] sdhci-pltfm: SDHCI platform and OF driver helper
[Tue Jul 5 06:01:40 2016] ledtrig-cpu: registered to indicate activity on CPUs
[Tue Jul 5 06:01:40 2016] hidraw: raw HID events driver (C) Jiri Kosina
[Tue Jul 5 06:01:40 2016] usbcore: registered new interface driver usbhid
[Tue Jul 5 06:01:40 2016] usbhid: USB HID core driver
[Tue Jul 5 06:01:40 2016] mmcblk0: p1 p2
[Tue Jul 5 06:01:40 2016] Initializing XFRM netlink socket
[Tue Jul 5 06:01:40 2016] NET: Registered protocol family 17
[Tue Jul 5 06:01:40 2016] Key type dns_resolver registered
[Tue Jul 5 06:01:40 2016] Registering SWP/SWPB emulation handler
[Tue Jul 5 06:01:40 2016] registered taskstats version 1
[Tue Jul 5 06:01:40 2016] vc-sm: Videocore shared memory driver
[Tue Jul 5 06:01:40 2016] [vc_sm_connected_init]: start
[Tue Jul 5 06:01:40 2016] [vc_sm_connected_init]: end - returning 0
[Tue Jul 5 06:01:40 2016] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[Tue Jul 5 06:01:40 2016] of_cfs_init
[Tue Jul 5 06:01:40 2016] of_cfs_init: OK
[Tue Jul 5 06:01:40 2016] Freeing unused kernel memory: 1792K (809ac000 - 80b6c000)
[Tue Jul 5 06:01:40 2016] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[Tue Jul 5 06:01:40 2016] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[Tue Jul 5 06:01:40 2016] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[Tue Jul 5 06:01:40 2016] Indeed it is in host mode hprt0 = 00021501
[Tue Jul 5 06:01:40 2016] mmc1: new high speed SDIO card at address 0001
[Tue Jul 5 06:01:40 2016] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[Tue Jul 5 06:01:40 2016] fsck: E2fsck run: /bin/e2fsck -p -C 0 /dev/mmcblk0p2
[Tue Jul 5 06:01:40 2016] fsck: Filesystem UUID: 9601954f-c8c7-4e50-8f5c-325269b29d55
[Tue Jul 5 06:01:40 2016] fsck: /dev/mmcblk0p2: clean, 31625/459648 files, 307213/1836800 blocks
[Tue Jul 5 06:01:40 2016] usb 1-1: new high-speed USB device number 2 using dwc_otg
[Tue Jul 5 06:01:40 2016] Indeed it is in host mode hprt0 = 00001101
[Tue Jul 5 06:01:40 2016] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[Tue Jul 5 06:01:40 2016] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[Tue Jul 5 06:01:40 2016] hub 1-1:1.0: USB hub found
[Tue Jul 5 06:01:40 2016] hub 1-1:1.0: 5 ports detected
[Tue Jul 5 06:01:40 2016] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[Tue Jul 5 06:01:40 2016] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[Tue Jul 5 06:01:40 2016] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[Tue Jul 5 06:01:40 2016] smsc95xx v1.0.4
[Tue Jul 5 06:01:40 2016] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:f3:f3:50
[Tue Jul 5 06:01:41 2016] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[Tue Jul 5 06:01:41 2016] random: systemd urandom read with 73 bits of entropy available
[Tue Jul 5 06:01:41 2016] NET: Registered protocol family 10
[Tue Jul 5 06:01:41 2016] usb 1-1.2: New USB device found, idVendor=0a12, idProduct=0001
[Tue Jul 5 06:01:41 2016] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[Tue Jul 5 06:01:41 2016] usb 1-1.2: Product: CSR8510 A10
[Tue Jul 5 06:01:41 2016] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[Tue Jul 5 06:01:41 2016] systemd[1]: Found ordering cycle on basic.target/start
[Tue Jul 5 06:01:41 2016] systemd[1]: Found dependency on sysinit.target/start
[Tue Jul 5 06:01:41 2016] systemd[1]: Found dependency on kbd.service/start
[Tue Jul 5 06:01:41 2016] systemd[1]: Found dependency on remote-fs.target/start
[Tue Jul 5 06:01:41 2016] systemd[1]: Found dependency on remote-fs-pre.target/start
[Tue Jul 5 06:01:41 2016] systemd[1]: Found dependency on connman.service/start
[Tue Jul 5 06:01:41 2016] systemd[1]: Found dependency on dbus.service/start
[Tue Jul 5 06:01:41 2016] systemd[1]: Found dependency on basic.target/start
[Tue Jul 5 06:01:41 2016] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[Tue Jul 5 06:01:41 2016] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[Tue Jul 5 06:01:41 2016] systemd[1]: Found dependency on rpcbind.service/start
[Tue Jul 5 06:01:41 2016] systemd[1]: Found dependency on network-online.target/start
[Tue Jul 5 06:01:41 2016] systemd[1]: Found dependency on network.target/start
[Tue Jul 5 06:01:41 2016] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[Tue Jul 5 06:01:41 2016] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[Tue Jul 5 06:01:41 2016] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[Tue Jul 5 06:01:41 2016] fuse init (API version 7.23)
[Tue Jul 5 06:01:41 2016] systemd-udevd[167]: starting version 215
[Tue Jul 5 06:01:42 2016] lirc_dev: IR Remote Control driver registered, major 245
[Tue Jul 5 06:01:42 2016] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[Tue Jul 5 06:01:42 2016] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[Tue Jul 5 06:01:42 2016] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[Tue Jul 5 06:01:42 2016] Bluetooth: Core ver 2.21
[Tue Jul 5 06:01:42 2016] NET: Registered protocol family 31
[Tue Jul 5 06:01:42 2016] Bluetooth: HCI device and connection manager initialized
[Tue Jul 5 06:01:42 2016] Bluetooth: HCI socket layer initialized
[Tue Jul 5 06:01:42 2016] Bluetooth: L2CAP socket layer initialized
[Tue Jul 5 06:01:42 2016] Bluetooth: SCO socket layer initialized
[Tue Jul 5 06:01:42 2016] usbcore: registered new interface driver brcmfmac
[Tue Jul 5 06:01:42 2016] random: nonblocking pool is initialized
[Tue Jul 5 06:01:42 2016] usbcore: registered new interface driver btusb
[Tue Jul 5 06:01:42 2016] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
[Tue Jul 5 06:01:42 2016] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[Tue Jul 5 06:01:42 2016] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[Tue Jul 5 06:01:43 2016] uart-pl011 3f201000.uart: no DMA platform data
[Tue Jul 5 06:01:43 2016] lirc_rpi: auto-detected active high receiver on GPIO pin 18
[Tue Jul 5 06:01:43 2016] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[Tue Jul 5 06:01:43 2016] lirc_rpi: driver registered!
[Tue Jul 5 06:01:43 2016] input: lircd as /devices/virtual/input/input0
[Tue Jul 5 06:01:44 2016] CIFS VFS: Error connecting to socket. Aborting operation.
[Tue Jul 5 06:01:44 2016] CIFS VFS: cifs_mount failed w/return code = -101
[Tue Jul 5 06:01:44 2016] systemd-journald[153]: Received request to flush runtime journal from PID 1
[Tue Jul 5 06:01:44 2016] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[Tue Jul 5 06:01:44 2016] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[Tue Jul 5 06:01:44 2016] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[Tue Jul 5 06:01:44 2016] brcmfmac: brcmf_add_if: ignore IF event
[Tue Jul 5 06:01:44 2016] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[Tue Jul 5 06:01:44 2016] brcmfmac: power management disabled
[Tue Jul 5 06:01:45 2016] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[Tue Jul 5 06:01:50 2016] Console: switching to colour dummy device 80x30
[Tue Jul 5 06:02:13 2016] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[Tue Jul 5 06:02:13 2016] Bluetooth: BNEP filters: protocol multicast
[Tue Jul 5 06:02:13 2016] Bluetooth: BNEP socket layer initialized
[Tue Jul 5 07:35:17 2016] input: 00:0C:8A:9A:FD:55 as /devices/virtual/input/input2
