There will be differences in VideoPlayer core, yes.
But v18 is very experimental and won’t be stable for a year. If you want stability or something that works well, you shouldn’t be using it and you should wait for v17 final.
Any ETA of the next update to V17 beta 6?
I like the Estuary GUI changes of beta 6
I will wait for Beta 7.
Proably Fix 100% cpu usage after a while while scanning for peripheral events by garbear · Pull Request #10921 · xbmc/xbmc · GitHub
Should be fixed in next build.
fine
So there is also an official OSMC update available?
Can I get this update via the “Update” inside “My OSMC”?
Which box are you using ?
Not yet.
I just installed Krypton, tried to add some ad-ons but there is some error, I cannot enter main repository.
This is discussed in this very thread 10 days ago.
Ups I should have look for this before. Mine addon.xml was referencing even to isengard…
Hi Sam. Do you plan to go straight to Krypton stable or there will be a last BETA 7 build before?
Maybe…
There will be RC builds before Final
The most important thing is that the Krypton release goes smoothly.
I trust that
Thanks Sam
This has been discussed way before that as well so why is it still not fixed?
It has been fixed, but there has been no new build produced with this fix yet.
