Is it possible to set up my Raspberry pi running OSMC with kodi into a wireless network router? Any help would be great!
I wouldnât recommend it. You have only one wired network interface, so would need to buy a switch, plus youâd also need a USB ethernet adapter for the WAN interface. Itâs all doable but a small router would probably be a better solution.
- Isnât this what the âtetheringâ option is supposed to do?
- A dedicated wireless router box will have a much better range and be faster.
- Depends what you have in mind, though (devices, connections)
@dillthedog
Only going to use wireless connections
- Doesnt tethering need another network? i didnt think it could become a hotspot and assign IPâs independently? If it can that solves my issue (currently at work have to look at it tonight)
- Range and speed isnt an issue
- This is for a portable Pi with kodi on it that i can control with my phone using Kore. Ideally i would just like to carry the Pi, hard drive and phone for the setup
So it seems that you donât want to âset up [your] Raspberry pi running OSMC with kodi into a wireless network routerâ though itâs still not entirely clear what you want.
If you donât want your Pi to be a wireless network router, what do you want? Do you want to view content on your phone or simply use the phone to control Kodi, which is how it now looks? If the latter, why is bluetooth not an option?
You could try tethering but I suspect it will fail if there is no active wired ethernet connection. It seems what you want is not a router but a direct or âad-hocâ connection.
Or you could do what I do and put everything onto a 128G SD card in the phone running kodi.
If the main point is to control kodi with the phone, it makes much more sense to enable the phone hotspot and direct osmc to connect to it. This way, the phone still has a data connection to the cellular network. If you try do this as originally suggested in this thread, the phone is then looking for internet from the pi where there is none.
