@sam_nazarko - The continue does not work as it does not allow me to pickup the UK stations. I will look to find a workaround. I do not use it that much - just bugging me that I cannot figure it out.
Thanks for the new release!!
If you are trying to pickup OTA stations with an antenna, I think you need to set the HDHomeRun to be used by TVHeadend in “Terrestrial” mode. Select the HDHomerun in the TV Adaptors list and you should see “Advanced Settings” “Network Type”, and you will want to select “DVB-T” (I’m in North America and use cable, so I use ATSC-C)
Then the correct options and frequencies should be available for you.
