Changed resolution to higher than what my TV allows. Tv now says not supported. Osmc did not go back to previous setting. How can I change back without resetting osmc completely?
If you changed it in Kodi settings then edit /home/osmc/.kodi/userdata/guisettings.xml I’m not sure which line to edit, hopefully you can figure it out and let us know
Alternatively you can delete/rename the guisettings file and reboot, this will set all Kodi settings to default.
Just had a look, maybe here:
<videoscreen>
<blankdisplays default="true">false</blankdisplays>
<fakefullscreen default="true">true</fakefullscreen>
<limitedrange default="true">false</limitedrange>
<limitgui default="true">0</limitgui>
<monitor default="true">Default</monitor>
<preferedstereoscopicmode default="true">100</preferedstereoscopicmode>
<resolution default="true">16</resolution>
<screen default="true">0</screen>
<screenmode default="true">DESKTOP</screenmode>
<stereoscopicmode default="true">0</stereoscopicmode>
<textures32 default="true">true</textures32>
<vsync default="true">2</vsync>
</videoscreen>
Probably easier to just rename it. But unfortunately I have no idea how to do that. I’m new to Linux and the Pi.
ssh into the PI then to rename it
sudo mv /home/osmc/.kodi/userdata/guisettings.xml /home/osmc/.kodi/userdata/guisettings.xml.bak
sudo reboot
or to edit it
nano /home/osmc/.kodi/userdata/guisettings.xml
