hi guys I used to use my tv remote to use with kodi but since the latest update it does not work is anyone elese having this problem or is it something ive done thanks ???
Probably something you’ve done, but what TV is the remote for, and are you trying to control via CEC?
Derek
@dandnsmith hi mate thanks for the reply from what I know I haven’t done anything and yes my tv remote used to control kodi but now does not thanks
Unplug both tne Tv and Pi FROM THE WALL then replug the TV and set it to correct inputs, now plug in the Pi. Things should now work, you may have to go into the TV CEC settings, Simplink or whatever the manufacturer calls it.
