I have a Panasonic P42G20 TV, so not so new, but working well TV. Osmc connecting directly to the TV.
I tried to check the cec-client -m, how ever it gives back an error that it could not open a connection.
cec-client -l was working.
libCEC version: 6.0.2, compiled on 2021-02-21 00:19:23 by root@compiler2 on Linux 4.19.0-9-amd64 (armv7l), features: P8_USB, DRM, P8_detect, Linux
Found devices: 1
device: 1
com port: Linux
vendor id: 0000
product id: 0000
firmware version: 0
type: Linux
After watching the episod, stopping somewhere in it:
STOP: (last log line)
2021-09-26 22:38:39.411 T:573 DEBUG : CDRMUtils::DrmFbGetFromBo - using modifier: 0x700000000000001
POWER OFF the TV via remote control: (last log line)
2021-09-26 22:39:34.073 T:767 DEBUG : CecLogMessage - >> 0f:36
and then wakeup starting from here.
2021-09-26 22:39:50.517 T:767 DEBUG : CecLogMessage - CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0000 phys_addr=ffff
2021-09-26 22:39:52.535 T:767 DEBUG : CecLogMessage - changing physical address to FFFF
2021-09-26 22:39:52.535 T:767 DEBUG : CecLogMessage - SetDevicePhysicalAddress - not setting invalid physical address ffff
2021-09-26 22:39:52.536 T:767 DEBUG : SetConfigurationFromLibCEC - settings updated by libCEC
2021-09-26 22:40:00.794 T:767 DEBUG : CecLogMessage - CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0000 phys_addr=1000
2021-09-26 22:40:00.928 T:767 DEBUG : CecLogMessage - CLinuxCECAdapterCommunication::Process - CEC_DQEVENT - CEC_EVENT_STATE_CHANGE - log_addr_mask=0010 phys_addr=1000
2021-09-26 22:40:00.928 T:767 DEBUG : CecLogMessage - changing physical address to 1000
Log file:
https://paste.osmc.tv/umanafuyay
What I have identified that if I wait until more time, then the long file name scrolling from left to right will stop and if I switch off the TV then the wake up maybe not happening or happens only very longer time.
But with the above example I was not waiting until the scrolling finished, so turned the TV off earlier and wakeup happend and I’ve seen the scrolling finished very soon. Maybe it has no connection to the problem maybe has, Have no clue.
In the log at the begining you will see another trial about watching the same episode then turn off, wait, but it was not waken up “soon” enough, so I did it again and was not waiting as much as I wrote it above. Maybe what could help that I do not use that view of films, episodes which has the thumbnails (library view maybe?) but the file view I’m using, where I going across the folders and select the right file.
hope this log will help more to you.
thanks
