When playing any 4k content my TV no longer switches to HDR mode and all colors are washed out.
https://paste.kodi.tv/udizolayih.kodi
Tried force 422 but that did not help.
Please use the log uploader in MyOSMC so we can get the big picture.
Thanks. Can you post mediainfo for the file you are trying to play, please?
None of my 4k files will work but here is the one from the log.
Format : Matroska
Format version : Version 4
File size : 43.1 GiB
Duration : 1 h 56 min
Overall bit rate : 52.9 Mb/s
Encoded date : UTC 2019-05-04 20:59:25
Writing application : mkvmerge v33.1.0 (‘Primrose’) 64-bit
Writing library : libebml v1.3.7 + libmatroska v1.5.0
Video
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile A compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 49.4 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (23976/1000) FPS
Original frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.248
Stream size : 40.3 GiB (93%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Audio
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 3 427 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 2.79 GiB (6%)
Language : English
Default : Yes
Forced : No
Thanks. I think the basic problem is you have quantisation range set to full. It should be limited.
Are you sure the TV is not switching to HDR mode?
My TV would always display the HDR logo when i played files before and the colors seem washed out now.
I might try and bypass my Yamaha receiver when i get time to troubleshoot more.
I have not changed any settings recently. It has always been on full but i will try switching it and see what happens.
Thanks for you help.
After more troubleshooting I have it figured out. It ended up being something weird with my TV.
I pulled the plug and let it reboot and now my HDR is working fine again.
Sorry to waste your time. Thanks.
No time waste. This may benefit other users with a similar display in the future.
