Hello, I am very new to this Vero 4k+ I recently got it and I struggle to get Tvheadend working propertly. When play on some tv channels with (25hz) it starts go slowly and not smooth at all. But when I play movie files it working normal (25hz). I have used my Raspberry Pi 3 and Tvheadend without any problems. Same setup same TV. Adjust Display Refresh Rate set to always. Why is it not working now with Vero 4k+? When I go to Setup I can not see 25hz under Refresh rate with Vero 4k+.
reboot the OSMC device
reproduce the issue
upload the log set either using the
Regards Tom.
