Hey all
Running on a Raspberry Pi 2 here and having an issue with the tvheadend client addon. I run a separate tvheadend server (on a Pi B) and use the tvheadend addon as a client on the OSMC Pi. I had it working at RC3 I think, and then it broke after an update. It was still broken after an update to the final version of OSMC. Also tried a fresh install and am experiencing the same problem.
I keep getting a “command failed:unable to stat path” error message popping up on screen every ten seconds or so. I can watch live TV and as far as I can tell, the tvheadend addon is otherwise operable.
The debug log file gives:
12:52:51 T:1479537696 ERROR: AddOnLog: Tvheadend HTSP Client: ReadResult - command failed - Unable to stat path
12:52:51 T:1479537696 DEBUG: CAddonCallbacksAddon - QueueNotification - Tvheadend HTSP Client - Error Message : ‘Command failed: Unable to stat path’
12:52:51 T:1479537696 DEBUG: AddOnLog: Tvheadend HTSP Client: GetDriveSpace - failed to get getDiskSpace
12:52:51 T:1957117952 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
I don’t understand what the GetDriveSpace thing is about, since it’s only operating as a client. Is it a permissions thing?
Thanks in advance
pp
