Hi all. Long time user of the 4K (not +) model, just updated to the latest version after finding the interface had gotten very sluggish.
This isn’t the issue, but mentioning for info in case relevant. I was using the Scope Nox skin as I have a fixed widescreen display, but it isn’t compatible with the latest software so have dropped back to OSMC skin.
However, UHD playback has pretty much died. I can get the image, but it is very jerky, either refreshes every 5-8 seconds, or just freezes. Sound is fine.
I didn’t have an issue pre-update, have a usb gigabit adapter, and am wired to an unmanaged gigabit switch connected direct to my router. Nothing has changed apart from the software update.
Any ideas?
EDIT: Just tried a few files and now get a ‘buffering’ message while paused, then a few seconds, then repeat
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
Thanks - logs uploaded, link as follows:
https://paste.osmc.tv/numuwudini
Watching the info at the top left of the screen while the movie was playing showed the CPU and 1/2/3/4 indicators maxing out at 100% repeatedly.
The log is blank – can you upload all logs?
Apologies. Should be fixed now:
Https://paste.osmc.tv/iruyamixuh
Note there seems to be a space between the .tv/ and the ‘iruy’ I have ignored
I have just checked and hardware acceleration was turned off. Turned on and it improved things somewhat.
That was my guess from 100% CPU usage.
Please post another debug log if you still get stutters.
