Shifting from LibreElec to OSMC, I installed the latest image (2021-12) for Raspberry Pi 3 today.
When Kodi is idle for one minute, the entire UI goes blank/black, then back on again. non stop until I hit some key (up / down, doesn’t matter) that would take it out of idle.
After one minute, it will go back to it again.
It’s not fast flickering, rather more of flashing every few hundreds of milliseconds. I’m talking about this happening at the rate of you reading: black… back… black… back… black… back…
I have a photos slide show screensaver (happens with other screensaver too), that kicks in after 3 minutes, and the flickering continues while it does.
All power saving options are off when this happens.
I was using the Estuary skip.
After getting no where with the configurations, I downloaded and wrote the prev image (2021-11). After completing the initial language, etc. setup, without doing any operation and with the default OSMC skip, this started happening again.
This happens in 1920x1080p 60Hz and 50Hz as well.
This doesn’t happen when I lower the resolution to 1280x720p.
When playing a movie, this doesn’t happen.
Any ideas?
