I just installed OSMC_TGT_rbp1_20160802.img.gz on my RP2. Everything is launching nomally on the confluence theme.
The only issue is when I try to connect to wifi with my EW-7811UN dongle.
I enable the wireless network, choose my network, type in my password then it keeps on connecting in a loop. can’t do much otherwise than uplugginf my RP.
I provided the log with this message.
Also, I do have a second RP2 with the exact same configuration and everything works smoothly.
To get a better understanding of the problem you are experiencing we need more information, including logs from you. Our wiki contains detailed steps for providing the relevant info we need to help you.
