When I try to update my OSMC (RPi 3) from the command line, I get the following error. It started around the time of the Stretch update (January?) I believe.
`Calculating upgrade… Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created
gnupg : Breaks: python-apt (<= 1.1.0~beta4) but 0.9.3.12 is to be installed
libsdl1.2-dev : Depends: libpulse-dev but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.`
Can anyone help out with what I need to do to get past this? I have installed non-core packages previously but I’m not sure which might be causing this issue (and why it’s only a problem now).
Thanks in advance.
