at my pi2 i want to unmount my usb device safe.
But when i write
sudo umount /dev/sda1
i tells me
unmount: command not found
so how do i unmount a usb device with ssh correctly ?
But when i write
i tells me
sudo sync && sudo umount /dev/sda1
is the correct way
If you look at the error you will see you typed unmount
instead of umount
oh thx, how stupid
and how do i mount it again safe ?
It will mount automatically when you plug it back in.
