Unsafe device removal, but power supplies seem ok?
Hi all;
I’ve been using OSMC for abour a year now and it is great, thank you for all the care and hard work!
Hopefully somebody might be able to help me with a storage issue I’ve been having lately.
I’m getting unsafe device removal of an external hdd on a raspberry pi 3 running the latest osmc version. I have read on the forums that the issue is commonly related to power supply, but in my setup the hdd is powered by its own original power supply, and the pi is powered by the official pi 3 power supply. Is it still likely a power supply issue? What might be other likely causes of such an error?
Thank you.
If you test by including a powered USB hub in the mix then you’ll have an answer.
Can you ssh in and report output of
vcgencmd get_throttled dmesg
After you have seen the unsafe removal message.
Ah… With power comes knowledge?
Thank you, I have no hub at present, would prefer troubleshooting before purchase if possible.
Thank you, will do and report back.
