Hi Guys.
I don’t know if I’m doing something wrong, but I can’t get the Up Next Addon working with my Local library.
How do I configure this Addon?
Did someone managed to get it working?
I thought it should be enough to install and activate it, but I didn’t get any notification from the add-on itself.
For the Library Integration Tool.
I installed it but i got an Error in the Logs when i’m trying to start it.
the Error is at the end of the log: https://paste.osmc.tv/muyosakigu.vhdl
Did you seek support from the add-on developer? Most mainstream add-ons have their own thread on the Kodi forum in the relevant subforum for the type of add-on. I’m not sure how this can be an OSMC problem and you will likely find much more relevant support for such an issue there.
Just wanted to know if anyone is using this addon on osmc successfully.
Second it was in the OSMC Add-on Repo. So thats the reason i asked here for support.
I will seek support on the Kodi Forum for this matter , thanks
works fine for me. It does need to be near the end time of the file though.
It does have a ‘test notification’ button in options so maybe delve there if it’s not popping the notification at all
