The update that just installed killed my cec. Is there a way to roll back, or are you aware of this issue? I can provide logs if you think it will help.
Yeah same here, it’s impossible turn off the TV sometimes. I disabled the CEC lib and it still didn’t work. I think I had a similar problem before and it was due to the library not being able to save it’s settings.
I upgraded to Raspberry Pi 3 and now I need to pull out the power cord every time I want to watch something, not that much faster even with the 64 bits. Doubt it’s a hardware issue though.
Ludespeeny:
You’ve posted under general support - but is your hardware RPi 1/2/3, Vero1/2, or ATV?
Ludespeeny and vtstn:
You should also have included logs, so there is some record of what happened.
Derek
