Update not working after 2016.02-1 Upgrade
Morning, well it is where I am…
I hope someone with a much bigger brain than my own could cast a knowledgeable eye over the attached log and tell me what the errors mean and why updates are not working (It seems that a file is missing but hey, what do I know)
Huge thanks in advance.
http://xbmclogs.com/phbvasezy
It won’t let me cut and paste the whole log.
You might have an issue with an unsupported skin. Try mv .kodi/userdata/guisettings.xml guisettings.xml and reboot
Also suggest to use grab-logs -A to upload logs.
Thanks for the reply.
Nope, all 3rd party skins have been removed. Only Confluence and the default OSMC skin remain.
Is grab-logs -A better than using the Kodi Log Uploader plugin?
Yes.
It is the same as using the all logs option in the My OSMC log uploader, but it can still be used even if Kodi is not working.
You already have 2 threads of your own discussing the issue you’re having with UPNP, please don’t thread-jack an unrelated thread.
Mine update isn’t working too (install apps from app store not working). instaled today from disk image (last one to rpi2)
“13:49:05 23.438583 T:1794769904 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<–
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type ‘exceptions.ValueError’>
Error Contents: day is out of range for month”
Looks like today isn’t a day for osmc :smiley: :smiley:
It’s not a good day for the search button on the forum either. It’s feeling very unloved and unused. :wink:
