When running update it goes to the update screen and sits still for a while, before saying update failed. OSMC restarts with an error message displayed: Error installing: login (1%3a4.2-3+deb8u1)
Well doesn’t look good as you also get a seg fault dpkg-deb: error: subprocess tar was killed by signal (Segmentation fault)
Maybe try to take away the overclock first to see if you can update then.
Exact same behaviour and error with overclock turned off.
Tar crashing is highly unusual.
Probably file system corruption. You could try clearing the apt cache then check for updates again to force them to be redownloaded:
sudo apt-get clean
I just reinstalled from installer and restored settings. Love that function! Thanks anyway.
