I’ve just tried to apply an update on my ATV.
The process stopped with a message warning about conflicts in NVIDEA drivers.
There was an OK button at the bottom, but the remote didn’t appear to be working whilst in update mode so I couldn’t get past this screen.
My only option to was to do a down/back button restart.
However, I think this caused the install not complete as I’m now getting lots of add-on errors.
For example, if I go back into My OSMC, Updates and then try and force an update check, I get an add-on error.
My movies all look like they play OK, but I’m worried about what hybrid state the failed update process may have caused.
Is there a way to reapply this update in full or should I do a reinstall?
