Hi there!
The latest update downloaded but I wasn’t ready to install it so I pressed no. Is there any way to update without having to re-download them?
Hi there!
Go to the Updates module in MyOSMC, and see the menu item Manual Controls. You can check for updates again there.
The “downloading” you see will be OSMC checking for even newer updates than the ones you already have.
The already downloaded files will be used unless there is a new version available.
Ahhhhhh that makes sense. Cheers for the quick reply
