Updated 12/1/17 at 4pm EST no wifi
installed updates, rebooted and lost wifi completely no menu option or anything
tryed sudo ifconfig wlan0 up returns no such device
running connman scan wifi comes back with Method “Scan” with signature “” on interface “net.connman.Technology” doesn’t exist
tested on 2 different osmc installs and both fail to see wifi device and bt device.
here is the log output
https://paste.osmc.tv/obequdanuy
Unpacking rbp2-device-osmc (1.4.4) …
dpkg: warning: overriding problem because --force enabled:
dpkg: warning: trying to overwrite ‘/usr/share/alsa/cards/JustBoomDigi.conf’, which is also in package libasound2-data 1.0.28-1+rpi3
dpkg: warning: trying to overwrite ‘/usr/share/alsa/cards/HifiberryDigi.conf’, which is also in package libasound2-data 1.0.28-1+rpi3
I was able to force the package to install and it fixed my issue of the missing wifi …
sudo dpkg --force-all --install /var/cache/apt/archives/rbp2-device-osmc_1.4.4_armhf.deb
It looks like something didn’t go right with the update as a result of you including the Raspberry Pi repository in the file /etc/apt/sources.list. You need to remove that line or further conflicts like this one are very likely to occur.
In this case, libasound2-data (rpi) is conflicting with rbp2-device-osmc, since they both try to write the same file: /usr/share/alsa/cards/HifiberryDigi.conf
Using --force simply masks the underlying problem, which is that you need to remove all the Raspbian packages with +rpi in the name and replace them with versions from the Debian repository. A quick scan of your log file brings up:
ii  libasound2:armhf                     1.0.28-1+rpi3                      armhf        shared library for ALSA applications
ii  libasound2-data                      1.0.28-1+rpi3                      all          Configuration files and profiles for ALSA drivers
ii  libcairo-gobject2:armhf              1.14.0-2.1+deb8u2+rpi1             armhf        Cairo 2D vector graphics library (GObject library)
ii  libcairo2:armhf                      1.14.0-2.1+deb8u2+rpi1             armhf        Cairo 2D vector graphics library
ii  libpam-modules:armhf                 1.1.8-3.1+deb8u2+rpi3              armhf        Pluggable Authentication Modules for PAM
ii  libpam-modules-bin                   1.1.8-3.1+deb8u2+rpi3              armhf        Pluggable Authentication Modules for PAM - helper binaries
ii  libpam-runtime                       1.1.8-3.1+deb8u2+rpi3              all          Runtime support for the PAM library
ii  libpam0g:armhf                       1.1.8-3.1+deb8u2+rpi3              armhf        Pluggable Authentication Modules library
Once you’re removed the Raspberry Pi repository from /etc/apt/sources.list, you should then run
sudo apt-get update
and for each of the 8 packages:
sudo apt-get install --reinstall <packagename>
Ok Thanks this was a custom build and i didnt realize that those sources were in there. thanks
