UPNP problems - browsing UPNP devices gives empty list
I have installed Hifiberry Digi+ version september (and tested also update of januari).
Looking for video on an external DLNA-server works only once, after activating UPNP-services in OSMC.
Browsing for video works fine after selecting DLNA-server in UPNP-list.
At next reboot, the list of UPNP devices is empty. The saved connection does not work.
I can only solve this by deactivating in OSMC the UPNP-services, followed by activating UPNP-services. Than, the saved connection is again live and list of UPNP-services no longer empty.
This is annoying. Do you have a solution?
Remark: I’m a newbee.
Ivo
Could be that kodi dismisses the saved upnp service at startup if it cannot find it.
Try activating “wait for network” in the myosmc networksettings.
Thank you!
this solved the problem.
kind regards
