I am running the latest OSMC on my RPi2 and very happy with everything except my USB HDD keeps on going into stanby mode and increasing the Load_Cycle_Count.
07:45:38 root@osmc ~# hdparm -I /dev/sda
/dev/sda:
ATA device, with non-removable media
Model Number: ST1000LM024 HN-M101MBB
Serial Number: S2RUJ9BDB06689
Firmware Revision: 2AR20003
Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0
Standards:
Used: unknown (minor revision code 0x0028)
Supported: 8 7 6 5
Likely used: 8
Configuration:
Logical max current
cylinders 16383 16383
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 268435455
LBA48 user addressable sectors: 1953525168
Logical Sector size: 512 bytes
Physical Sector size: 4096 bytes
Logical Sector-0 offset: 0 bytes
device size with M = 1024*1024: 953869 MBytes
device size with M = 1000*1000: 1000204 MBytes (1000 GB)
cache/buffer size = 16384 KBytes
Form Factor: 2.5 inch
Nominal Media Rotation Rate: 5400
Capabilities:
LBA, IORDY(can be disabled)
Queue depth: 32
Standby timer values: spec'd by Standard, no device specific minimum
R/W multiple sector transfer: Max = 16 Current = ?
Advanced power management level: 254
Recommended acoustic management value: 254, current value: 0
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
* SMART feature set
Security Mode feature set
* Power Management feature set
* Write cache
* Look-ahead
* Host Protected Area feature set
* WRITE_BUFFER command
* READ_BUFFER command
* NOP cmd
* DOWNLOAD_MICROCODE
* Advanced Power Management feature set
Power-Up In Standby feature set
* SET_FEATURES required to spinup after power up
SET_MAX security extension
Automatic Acoustic Management feature set
* 48-bit Address feature set
* Device Configuration Overlay feature set
* Mandatory FLUSH_CACHE
* FLUSH_CACHE_EXT
* SMART error logging
* SMART self-test
* General Purpose Logging feature set
* 64-bit World wide name
* IDLE_IMMEDIATE with UNLOAD
* WRITE_UNCORRECTABLE_EXT command
* {READ,WRITE}_DMA_EXT_GPL commands
* Segmented DOWNLOAD_MICROCODE
* Gen1 signaling speed (1.5Gb/s)
* Gen2 signaling speed (3.0Gb/s)
* Native Command Queueing (NCQ)
* Phy event counters
* Idle-Unload when NCQ is active
* NCQ priority information
DMA Setup Auto-Activate optimization
Device-initiated interface power management
* Software settings preservation
* SMART Command Transport (SCT) feature set
* SCT Read/Write Long (AC1), obsolete
* SCT Write Same (AC2)
* SCT Error Recovery Control (AC3)
* SCT Features Control (AC4)
* SCT Data Tables (AC5)
Security:
Master password revision code = XXXXX
supported
not enabled
not locked
not frozen
not expired: security count
supported: enhanced erase
208min for SECURITY ERASE UNIT. 208min for ENHANCED SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 50004cf20ba310b6
NAA : 5
IEEE OUI : 0004cf
Unique ID : 20ba310b6
Checksum: correct
I made sure APM was disabled with:
07:45:44 root@osmc ~# hdparm -B /dev/sda
/dev/sda:
APM_level = 254
APM level 254 is correct, if I change it to 255, the Load_Cycle_Count increases quicker.
After making sure the drive has APM disabled, I am still seeing the Load_Cycle_Count increase around 1 digit every 30 minutes. The USB HDD also has a blue LED which I see power off during standby.
Any advice?
Thanks in advance.
