Some days ago I decided to reinstall my Kodi setup, with some other services (Lidarr, Jackett and Transmission). Everything was working, but for some weird reason seems I corrupted my SD.
So I ordered another cheap SD card and an USB 3.0, thinking that setup would be harder to corrupt and I would get better performance. Since first moment I was feeling everything more slow, so once everything was installed again I tried to benchmark write/read rates based on this thread Usb install vs sdcard - #21 by Zappatron My results:
Write
root@osmc:/home/osmc# dd if=/dev/zero of=test bs=1M count=512 conv=fdatasync
512+0 records in
512+0 records out
536870912 bytes (537 MB, 512 MiB) copied, 71.0382 s, 7.6 MB/s
Read
root@osmc:/home/osmc# free && sync && echo 3 > /proc/sys/vm/drop_caches && free && dd if=test of=/dev/null bs=1M count=512
total used free shared buff/cache available
Mem: 764724 357744 34208 5144 372772 347464
Swap: 0 0 0
Mem: 764724 358300 299624 5144 106800 350924
Swap: 0 0 0
512+0 records in
512+0 records out
536870912 bytes (537 MB, 512 MiB) copied, 21.9898 s, 24.4 MB/s
In comparison with thread results (SD instalation, Raspberry 2), and thinking my instalation is on an USB 3.0 flash drive, I though I am getting a really bad results specially on write (7.6 MB/s to 12.7 MB/s).
Is this OK? Is there a way to move all my installation to and SD in order to give it a try?
My setup
Raspberry 3 (old, so I supposed is A version?)
USB Kingston DataTraveller 16 GB
Kingston SD card
An external HD Seagate (not powered by Raspi, external power)
dunno why you went with DD when hdparm is installed.
Cause I am not really know what I am doing
Here my metrics:
/dev/sda:
Timing cached reads: 8 MB in 2.00 seconds = 4.00 MB/sec
Timing buffered disk reads: 92 MB in 3.02 seconds = 30.44 MB/sec
Yeah, there is not a typo everything is taken forever…
I returned home right now, and seems Transmission has stopped. Not sure why. If I check status says Main PID: 465 (code=killed, signal=KILL)
Also said I have overclocked my raspi to Turbo (after my first message), just to see if that could help. But I think is going to be worse.
Can not check power adapter right now, but I think is 1 - 1.5 A . What value should be enough?
that jbd2 proccess its eating 40/50 % IO all the time. Searched for it on google and found some suggestions about set noatime on fstab. Went there and found the following:
/dev/mmcblk0p1 /boot vfat defaults,noatime,noauto,x-systemd.automount 0 0
# rootfs is not mounted in fstab as we do it via initramfs. Uncomment for remount (slower boot)
#/dev/sda1 / ext4 defaults,noatime 0 0
So not sure if uncomment last line, as system is there and I am worried of breaking everything. Also, should I set a line for my external HD? At this moment I need to unplug each time I reboot the system.
Seems you got a lot of stuff on your rpi, I tend to split up what a raspberry does if a raspberry is a mediacenter then its purpose is a mediacenter not a general downloader
many seem to crap as much as possible into a rpi thus overloading it.
would recommend setting up all that downloaders on a separate rpi, plus im not a fan of mono since its not native to Linux it tends to be a resource hog and kodi by itself can be quite a hungry beast
