I installed OSMC on a sd card on a Pi 3, Model B, v1.2. I connected it to my TV and I get the language select screen but my USB mouse does not work. I see the mouse light up on boot but then once OSMC is booted and it is at the language select screen, the light on the mouse turns off.
It is either does not like my Dell Mouse or I am not getting enough power to it?! I do not know how to boot this sd card from PC to run any commands or see the log files.
The img file I installed on my SD card is OSMC_TGT_rbp2_20170210.img.
Mouse and keyboard not working. I am using an official power source too. I installed a remote control app for the pi and that is working so I did the initial setup that way. But what a drag. I really want the USB mouse and keyboard to work with the pi but maybe it has to do with the bootup config file which needs editing or configuring. Still doing research.
I occasionally receive a dbus notification error. The message tells me to check the logs but IAM a noob here, an adult infant hoping to find a bigger brain who can lead me to a solution.
So I assume your original problem USB mouse/keyboard still not working?
Also earlier you wrote it is a “DELL”, can not see any entries for that in the USB devices.
Suggest to install usb-utils sudo apt-get install usb-utils and then boot OSMC without them connected then attach one after the other and when both connected provide the output of: lsusb | paste-log dmesg | paste-log
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
No USB devices are found to be connected so either your USB ports are broken or some other incompatibility exists
