I must be an idiot, the quick start guide mentions a USB receiver that you plug in for the remote. I bought 2 Vero 4k boxes and I cannot find any USB receivers in either box. I used to have a Rii Remote so I know what I think I should be looking for.
I know I do not have that bag anymore, but I am quite a careful person, I don’t think I would have thrown it out. I’ll have to search like crazy
The remote is weighed before shipment and includes a receiver stuck to the back of each remote. It wouldn’t be possible to ship two remotes without a receiver, let alone one.
Check the bin and you should find them. A lot of people rip the plastic bag open to take the remote out and neglect to see the dongle on the back until consulting the manual.
I must have misplaced them then. I have my left over usb receiver from the Rii, is it possible to pair them?
The OSMC dongle is needed unfortunately.
If you can’t find them, then email support@osmc.tv for replacements.
I’ve received your email and checked this in further detail.
We package the OSMC remote face down to make sure it travels more safely and to check a dongle is included.
We can ship you a couple of replacements. When you get them, you’ll need to re-pair the remote.
- Hold Home and OK button for 5 seconds or so, then the blue LED will keep flashing.
- Plug in the USB receiver and the LED should flash 3 times after 5 seconds, indicating successful pairing.
- Power off Vero 4K for 2 minutes. Turn it back on. The remote should now work
