USB Sound Cards on OSMC running on RPi
Hi ,
Has support for USB sound cards added in the OSMC Alpha 3 build for Raspberry Pi ?
I’m planning on buying this sound card http://www.amazon.in/dp/B00CP53ML2/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=1CADPY8R6157P&coliid=INRXFFL4GIWWV
Will this work on my RPi running on OSMC alpha 3?
Or do i have to go back to RaspBMC ?
WIll it work in RaspBMC ?
Sorry if my question is noobish .
USB sound cards should work out of the box on Alpha 3 and should be selectable from Settings.
Thank you!!!
Its a pleasure to hear it from Sam himself :smile:
