Hello, seem to have an issue with no sound being passed through my Raspberry Pi 3 when playing movie files. I have the OSMC July 2016 update installed ok and have no playback issues with my Sony TV and Sony soundbar.
But I have some movies on a USB stick which I have inserted into the USB bank on the PI and I can access them via the Kodi/OSMC File Explorer.
But when I play them, no sound is being heard at all.
As far I can can see, I have all the passthrough settings correct on the Sony Soundbar (connected via the ARC HDMI port) and on Kodi so I can’t see any obvious mistake?
To get a better understanding of the problem you are experiencing we need more information, including logs from you. Please see How to submit a useful support request - General - OSMC for advice on how to help us help you.
Ok installed Mediainfo app and here is the details I have back when I opened one of the MKV:
General
Complete name : Insurrection S1 E8.mkv
Format : Matroska
Format version : Version 1
File size : 879 MiB
Duration : 23 min
Overall bit rate : 5 141 kb/s
Encoded date : UTC 2016-07-24 16:24:44
Writing library : WonderShare Matroska Muxer
Video
Format : AVC
Format profile : Main@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=25
Codec ID : V_MPEG4/ISO/AVC
Duration : 23 min
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Default : Yes
Forced : No
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 23 min
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 spf)
Compression mode : Lossy
Default : Yes
Forced : No
Ok… there is a port called TV (ARC) on the soundbar and I have it connected to the ARC port on the Sony TV… the Raspberry Pi is connected to a HDMI port on the TV.
