Just plumbed in my Vero V after 6 years of using a Vero 4k+. I run a simple, no extras set up with media playing from an external powered HDD via a decent USB3 cable.
First thing I noticed was the remote control ‘lag’ (after replacing the dead battery). Some button presses seem to be ignored (but could be simply be lack of finger pressure as I’m used to a worn remote).
But the USB 3 port (the lower of the two, I presume) doesn’t seem to do anything. I plug in the drive, power it up, and nothing happens. Connecting the same drive to the USB2 port results in the drive being recognised within a few seconds, similar to what I’m used to with the V4k+.
However, I am noticing media taking longer to start running. Up to 20 seconds from button press to the AV starting playing. However, playback is crisp and audio is good.
Only other problem is the damn fast forward glitch. It spannered my V4k+, and here it is again - although the V5 recovers quicker. Still incredibly annoying, though. Bring on the next update. ![]()
Any help or suggestions for what I’ve missed regarding the USB3 configuration/setup would be appreciated. Thank you.
