Can Sickbeards metadata be used for OSMC? Several shows that are on my server show up as incorrect shows in OSMC but show up correct in sickbeard such as the office and shameless as there are two versions of the shows. If this cann’t be done is there a way to change the show manually from the frontend or the data base in the backend? also does WinSCP work with OSMC?
I use WinSCP, it works. There’s no reason it wouldnt.
As for the TV show info, select “refresh” and it will display a list of shows similar to the one selected.
Perfect Thank you
Happy to help
o7
