With the pi running Raspbian I have a powered usb hub attached that provides power to two external hard drives. Would that still be an issue? On the other one only the DVT dongle is attached.
Well for testing purpose I would just take the plain device without any dongles or hubs attached.
If it then doesnât show up even on a fresh raspbian install it can be considered a hardware failure
Done! Although, still the same result neither Pis show there wifi coming up.
Which than point to a hardware failure
Ah well, at least I can still use the Ethernet! Not worth buying new pis at the moment and I think I might have a few usb wifi dongles floating around I could try to see if that solves the wifi problem.
I have discovered that the pi with just Raspbian on it is switching between to different ip addresses for the Ethernet connection! This is happening with a fresh install of the Operating System.
Edit:
This is the result of dmesg after uninstalling then reinstalling brcmfmac.
[ 18.609443] brcmfmac: brcmf_sdio_hostmail: Unknown mailbox data content: 0x40 012
[ 21.111501] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[ 21.114903] brcmfmac: brcmf_sdio_checkdied: firmware trap in dongle
[ 23.671583] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[ 23.675044] brcmfmac: brcmf_sdio_checkdied: firmware trap in dongle
[ 23.675058] brcmfmac: brcmf_pno_clean: failed code -110
[ 30.271790] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null)
[ 30.378665] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[ 31.191531] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[ 31.194987] brcmfmac: brcmf_sdio_checkdied: firmware trap in dongle
[ 31.195001] brcmfmac: brcmf_do_escan: error (-110)
[ 31.195005] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 93.591511] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[ 93.595112] brcmfmac: brcmf_sdio_checkdied: firmware trap in dongle
[ 93.595127] brcmfmac: brcmf_do_escan: error (-110)
[ 93.595134] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 153.591509] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[ 153.595106] brcmfmac: brcmf_sdio_checkdied: firmware trap in dongle
[ 153.595120] brcmfmac: brcmf_do_escan: error (-110)
[ 153.595130] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 213.591528] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[ 213.595151] brcmfmac: brcmf_sdio_checkdied: firmware trap in dongle
[ 213.595165] brcmfmac: brcmf_do_escan: error (-110)
[ 213.595173] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 273.591525] brcmfmac: brcmf_do_escan: error (-110)
[ 273.591540] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 333.591522] brcmfmac: brcmf_do_escan: error (-110)
[ 333.591536] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 393.591525] brcmfmac: brcmf_do_escan: error (-110)
[ 393.591539] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 453.591523] brcmfmac: brcmf_do_escan: error (-110)
[ 453.591537] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 513.591537] brcmfmac: brcmf_do_escan: error (-110)
[ 513.591552] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 573.591533] brcmfmac: brcmf_do_escan: error (-110)
[ 573.591547] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 633.591531] brcmfmac: brcmf_do_escan: error (-110)
[ 633.591543] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 693.591516] brcmfmac: brcmf_do_escan: error (-110)
[ 693.591528] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 753.591532] brcmfmac: brcmf_do_escan: error (-110)
[ 753.591545] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 813.591522] brcmfmac: brcmf_do_escan: error (-110)
[ 813.591534] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 873.591516] brcmfmac: brcmf_do_escan: error (-110)
[ 873.591529] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 933.591516] brcmfmac: brcmf_do_escan: error (-110)
[ 933.591529] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 993.591793] brcmfmac: brcmf_do_escan: error (-110)
[ 993.591806] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1053.592082] brcmfmac: brcmf_do_escan: error (-110)
[ 1053.592095] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1113.592967] brcmfmac: brcmf_do_escan: error (-110)
[ 1113.592979] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1173.594087] brcmfmac: brcmf_do_escan: error (-110)
[ 1173.594099] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1233.595051] brcmfmac: brcmf_do_escan: error (-110)
[ 1233.595064] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1293.595883] brcmfmac: brcmf_do_escan: error (-110)
[ 1293.595897] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1353.596610] brcmfmac: brcmf_do_escan: error (-110)
[ 1353.596622] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1413.597253] brcmfmac: brcmf_do_escan: error (-110)
[ 1413.597266] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1473.597842] brcmfmac: brcmf_do_escan: error (-110)
[ 1473.597855] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1533.598376] brcmfmac: brcmf_do_escan: error (-110)
[ 1533.598389] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1593.599156] brcmfmac: brcmf_do_escan: error (-110)
[ 1593.599169] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1653.599851] brcmfmac: brcmf_do_escan: error (-110)
[ 1653.599864] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1713.600484] brcmfmac: brcmf_do_escan: error (-110)
[ 1713.600497] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1773.601068] brcmfmac: brcmf_do_escan: error (-110)
[ 1773.601081] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1833.601607] brcmfmac: brcmf_do_escan: error (-110)
[ 1833.601620] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1893.602136] brcmfmac: brcmf_do_escan: error (-110)
[ 1893.602148] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 1953.602747] brcmfmac: brcmf_do_escan: error (-110)
[ 1953.602760] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2013.603294] brcmfmac: brcmf_do_escan: error (-110)
[ 2013.603308] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2073.603798] brcmfmac: brcmf_do_escan: error (-110)
[ 2073.603811] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2133.604259] brcmfmac: brcmf_do_escan: error (-110)
[ 2133.604272] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2193.604581] brcmfmac: brcmf_do_escan: error (-110)
[ 2193.604593] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2253.604918] brcmfmac: brcmf_do_escan: error (-110)
[ 2253.604930] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2313.605277] brcmfmac: brcmf_do_escan: error (-110)
[ 2313.605289] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2373.605636] brcmfmac: brcmf_do_escan: error (-110)
[ 2373.605649] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2433.606010] brcmfmac: brcmf_do_escan: error (-110)
[ 2433.606023] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2493.606384] brcmfmac: brcmf_do_escan: error (-110)
[ 2493.606397] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2553.606775] brcmfmac: brcmf_do_escan: error (-110)
[ 2553.606788] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2613.607163] brcmfmac: brcmf_do_escan: error (-110)
[ 2613.607177] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2673.607557] brcmfmac: brcmf_do_escan: error (-110)
[ 2673.607570] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2733.607954] brcmfmac: brcmf_do_escan: error (-110)
[ 2733.607966] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2793.608355] brcmfmac: brcmf_do_escan: error (-110)
[ 2793.608367] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2853.608759] brcmfmac: brcmf_do_escan: error (-110)
[ 2853.608773] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2913.609153] brcmfmac: brcmf_do_escan: error (-110)
[ 2913.609166] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 2973.609570] brcmfmac: brcmf_do_escan: error (-110)
[ 2973.609583] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3033.609958] brcmfmac: brcmf_do_escan: error (-110)
[ 3033.609971] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3093.610371] brcmfmac: brcmf_do_escan: error (-110)
[ 3093.610383] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3153.610717] brcmfmac: brcmf_do_escan: error (-110)
[ 3153.610730] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3213.611014] brcmfmac: brcmf_do_escan: error (-110)
[ 3213.611029] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3273.611302] brcmfmac: brcmf_do_escan: error (-110)
[ 3273.611314] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3333.611546] brcmfmac: brcmf_do_escan: error (-110)
[ 3333.611559] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3393.611800] brcmfmac: brcmf_do_escan: error (-110)
[ 3393.611813] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3453.612056] brcmfmac: brcmf_do_escan: error (-110)
[ 3453.612069] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3513.612335] brcmfmac: brcmf_do_escan: error (-110)
[ 3513.612348] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3573.612632] brcmfmac: brcmf_do_escan: error (-110)
[ 3573.612644] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3633.612956] brcmfmac: brcmf_do_escan: error (-110)
[ 3633.612969] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3693.613240] brcmfmac: brcmf_do_escan: error (-110)
[ 3693.613253] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3753.613558] brcmfmac: brcmf_do_escan: error (-110)
[ 3753.613570] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3813.613887] brcmfmac: brcmf_do_escan: error (-110)
[ 3813.613899] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3873.614221] brcmfmac: brcmf_do_escan: error (-110)
[ 3873.614234] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3933.694556] brcmfmac: brcmf_do_escan: error (-110)
[ 3933.694569] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 3993.694911] brcmfmac: brcmf_do_escan: error (-110)
[ 3993.694924] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4053.695257] brcmfmac: brcmf_do_escan: error (-110)
[ 4053.695270] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4113.695613] brcmfmac: brcmf_do_escan: error (-110)
[ 4113.695628] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4173.695973] brcmfmac: brcmf_do_escan: error (-110)
[ 4173.695986] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4233.696339] brcmfmac: brcmf_do_escan: error (-110)
[ 4233.696351] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4293.696705] brcmfmac: brcmf_do_escan: error (-110)
[ 4293.696718] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4353.697053] brcmfmac: brcmf_do_escan: error (-110)
[ 4353.697067] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4413.697299] brcmfmac: brcmf_do_escan: error (-110)
[ 4413.697312] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4473.697516] brcmfmac: brcmf_do_escan: error (-110)
[ 4473.697529] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4533.697772] brcmfmac: brcmf_do_escan: error (-110)
[ 4533.697785] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4593.698047] brcmfmac: brcmf_do_escan: error (-110)
[ 4593.698060] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4653.698312] brcmfmac: brcmf_do_escan: error (-110)
[ 4653.698325] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4713.698583] brcmfmac: brcmf_do_escan: error (-110)
[ 4713.698596] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4773.698862] brcmfmac: brcmf_do_escan: error (-110)
[ 4773.698877] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4833.699158] brcmfmac: brcmf_do_escan: error (-110)
[ 4833.699170] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4893.699456] brcmfmac: brcmf_do_escan: error (-110)
[ 4893.699469] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 4953.699763] brcmfmac: brcmf_do_escan: error (-110)
[ 4953.699776] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5013.700078] brcmfmac: brcmf_do_escan: error (-110)
[ 5013.700091] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5073.700402] brcmfmac: brcmf_do_escan: error (-110)
[ 5073.700415] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5133.700721] brcmfmac: brcmf_do_escan: error (-110)
[ 5133.700734] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5193.701058] brcmfmac: brcmf_do_escan: error (-110)
[ 5193.701070] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5253.701391] brcmfmac: brcmf_do_escan: error (-110)
[ 5253.701404] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5313.701730] brcmfmac: brcmf_do_escan: error (-110)
[ 5313.701745] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5373.702077] brcmfmac: brcmf_do_escan: error (-110)
[ 5373.702089] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5433.702413] brcmfmac: brcmf_do_escan: error (-110)
[ 5433.702425] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5493.702764] brcmfmac: brcmf_do_escan: error (-110)
[ 5493.702777] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5553.703111] brcmfmac: brcmf_do_escan: error (-110)
[ 5553.703156] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5613.703440] brcmfmac: brcmf_do_escan: error (-110)
[ 5613.703452] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5673.703774] brcmfmac: brcmf_do_escan: error (-110)
[ 5673.703787] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5733.704118] brcmfmac: brcmf_do_escan: error (-110)
[ 5733.704160] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5793.704452] brcmfmac: brcmf_do_escan: error (-110)
[ 5793.704465] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5853.704784] brcmfmac: brcmf_do_escan: error (-110)
[ 5853.704796] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5913.705121] brcmfmac: brcmf_do_escan: error (-110)
[ 5913.705134] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 5973.705465] brcmfmac: brcmf_do_escan: error (-110)
[ 5973.705477] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6033.705823] brcmfmac: brcmf_do_escan: error (-110)
[ 6033.705836] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6093.706169] brcmfmac: brcmf_do_escan: error (-110)
[ 6093.706181] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6153.706502] brcmfmac: brcmf_do_escan: error (-110)
[ 6153.706515] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6213.706847] brcmfmac: brcmf_do_escan: error (-110)
[ 6213.706859] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6273.707233] brcmfmac: brcmf_do_escan: error (-110)
[ 6273.707246] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6333.707545] brcmfmac: brcmf_do_escan: error (-110)
[ 6333.707558] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6393.707898] brcmfmac: brcmf_do_escan: error (-110)
[ 6393.707911] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6453.708248] brcmfmac: brcmf_do_escan: error (-110)
[ 6453.708261] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6513.708649] brcmfmac: brcmf_do_escan: error (-110)
[ 6513.708662] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6573.708958] brcmfmac: brcmf_do_escan: error (-110)
[ 6573.708971] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6633.709318] brcmfmac: brcmf_do_escan: error (-110)
[ 6633.709331] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6693.709666] brcmfmac: brcmf_do_escan: error (-110)
[ 6693.709679] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6753.709998] brcmfmac: brcmf_do_escan: error (-110)
[ 6753.710026] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6813.710336] brcmfmac: brcmf_do_escan: error (-110)
[ 6813.710348] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6873.710688] brcmfmac: brcmf_do_escan: error (-110)
[ 6873.710700] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6933.711033] brcmfmac: brcmf_do_escan: error (-110)
[ 6933.711045] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 6993.711363] brcmfmac: brcmf_do_escan: error (-110)
[ 6993.711376] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7053.711706] brcmfmac: brcmf_do_escan: error (-110)
[ 7053.711718] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7113.712084] brcmfmac: brcmf_do_escan: error (-110)
[ 7113.712097] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7173.712390] brcmfmac: brcmf_do_escan: error (-110)
[ 7173.712403] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7233.712731] brcmfmac: brcmf_do_escan: error (-110)
[ 7233.712743] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7293.713089] brcmfmac: brcmf_do_escan: error (-110)
[ 7293.713101] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7353.713429] brcmfmac: brcmf_do_escan: error (-110)
[ 7353.713441] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7413.713785] brcmfmac: brcmf_do_escan: error (-110)
[ 7413.713797] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7473.714150] brcmfmac: brcmf_do_escan: error (-110)
[ 7473.714176] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7533.714511] brcmfmac: brcmf_do_escan: error (-110)
[ 7533.714539] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7593.714872] brcmfmac: brcmf_do_escan: error (-110)
[ 7593.714886] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7653.795237] brcmfmac: brcmf_do_escan: error (-110)
[ 7653.795249] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7713.795601] brcmfmac: brcmf_do_escan: error (-110)
[ 7713.795613] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7773.795967] brcmfmac: brcmf_do_escan: error (-110)
[ 7773.795979] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7833.796331] brcmfmac: brcmf_do_escan: error (-110)
[ 7833.796344] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7893.796692] brcmfmac: brcmf_do_escan: error (-110)
[ 7893.796704] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 7953.797143] brcmfmac: brcmf_do_escan: error (-110)
[ 7953.797190] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8013.797422] brcmfmac: brcmf_do_escan: error (-110)
[ 8013.797434] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8073.797783] brcmfmac: brcmf_do_escan: error (-110)
[ 8073.797795] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8133.798202] brcmfmac: brcmf_do_escan: error (-110)
[ 8133.798215] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8193.798511] brcmfmac: brcmf_do_escan: error (-110)
[ 8193.798524] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8253.798875] brcmfmac: brcmf_do_escan: error (-110)
[ 8253.798888] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8313.799242] brcmfmac: brcmf_do_escan: error (-110)
[ 8313.799255] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8373.799607] brcmfmac: brcmf_do_escan: error (-110)
[ 8373.799619] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8433.799970] brcmfmac: brcmf_do_escan: error (-110)
[ 8433.799983] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8493.800335] brcmfmac: brcmf_do_escan: error (-110)
[ 8493.800348] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8553.800725] brcmfmac: brcmf_do_escan: error (-110)
[ 8553.800738] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8613.801077] brcmfmac: brcmf_do_escan: error (-110)
[ 8613.801091] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8673.801429] brcmfmac: brcmf_do_escan: error (-110)
[ 8673.801464] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8733.801786] brcmfmac: brcmf_do_escan: error (-110)
[ 8733.801799] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8793.802155] brcmfmac: brcmf_do_escan: error (-110)
[ 8793.802168] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8853.802518] brcmfmac: brcmf_do_escan: error (-110)
[ 8853.802531] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8913.802877] brcmfmac: brcmf_do_escan: error (-110)
[ 8913.802891] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 8973.803246] brcmfmac: brcmf_do_escan: error (-110)
[ 8973.803259] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9033.803611] brcmfmac: brcmf_do_escan: error (-110)
[ 9033.803624] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9093.803968] brcmfmac: brcmf_do_escan: error (-110)
[ 9093.803981] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9153.804337] brcmfmac: brcmf_do_escan: error (-110)
[ 9153.804349] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9213.804713] brcmfmac: brcmf_do_escan: error (-110)
[ 9213.804726] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9273.805063] brcmfmac: brcmf_do_escan: error (-110)
[ 9273.805075] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9333.805434] brcmfmac: brcmf_do_escan: error (-110)
[ 9333.805447] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9393.805805] brcmfmac: brcmf_do_escan: error (-110)
[ 9393.805818] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9453.806162] brcmfmac: brcmf_do_escan: error (-110)
[ 9453.806175] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9513.806536] brcmfmac: brcmf_do_escan: error (-110)
[ 9513.806550] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9573.806896] brcmfmac: brcmf_do_escan: error (-110)
[ 9573.806909] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9633.807267] brcmfmac: brcmf_do_escan: error (-110)
[ 9633.807282] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9693.807628] brcmfmac: brcmf_do_escan: error (-110)
[ 9693.807641] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9753.807985] brcmfmac: brcmf_do_escan: error (-110)
[ 9753.807998] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9813.808320] brcmfmac: brcmf_do_escan: error (-110)
[ 9813.808332] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9873.808654] brcmfmac: brcmf_do_escan: error (-110)
[ 9873.808667] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9933.808982] brcmfmac: brcmf_do_escan: error (-110)
[ 9933.808996] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[ 9993.809312] brcmfmac: brcmf_do_escan: error (-110)
[ 9993.809325] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10053.809646] brcmfmac: brcmf_do_escan: error (-110)
[10053.809659] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10113.809977] brcmfmac: brcmf_do_escan: error (-110)
[10113.809989] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10173.810307] brcmfmac: brcmf_do_escan: error (-110)
[10173.810320] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10233.810641] brcmfmac: brcmf_do_escan: error (-110)
[10233.810655] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10293.810978] brcmfmac: brcmf_do_escan: error (-110)
[10293.810992] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10353.811313] brcmfmac: brcmf_do_escan: error (-110)
[10353.811325] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10413.811658] brcmfmac: brcmf_do_escan: error (-110)
[10413.811670] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10473.811978] brcmfmac: brcmf_do_escan: error (-110)
[10473.811990] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10533.812320] brcmfmac: brcmf_do_escan: error (-110)
[10533.812333] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10593.812661] brcmfmac: brcmf_do_escan: error (-110)
[10593.812673] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10653.812998] brcmfmac: brcmf_do_escan: error (-110)
[10653.813010] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10713.813332] brcmfmac: brcmf_do_escan: error (-110)
[10713.813344] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10773.813669] brcmfmac: brcmf_do_escan: error (-110)
[10773.813682] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10833.813992] brcmfmac: brcmf_do_escan: error (-110)
[10833.814005] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10893.814313] brcmfmac: brcmf_do_escan: error (-110)
[10893.814325] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[10953.814640] brcmfmac: brcmf_do_escan: error (-110)
[10953.814652] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[11013.814942] brcmfmac: brcmf_do_escan: error (-110)
[11013.814955] brcmfmac: brcmf_cfg80211_scan: scan error (-110)
[11023.804980] brcmfmac: brcmf_fil_cmd_data: bus is down. we have nothing to do.
[11023.805048] brcmfmac: brcmf_fil_cmd_data: bus is down. we have nothing to do.
[11023.806216] brcmfmac: brcmf_fil_cmd_data: bus is down. we have nothing to do.
[11023.806231] brcmfmac: brcmf_cfg80211_get_channel: chanspec failed (-5)
[11024.026827] usbcore: deregistering interface driver brcmfmac
[11041.819267] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[11041.826831] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdi o.bin for chip 0x00a9a6(43430) rev 0x000001
[11041.827138] usbcore: registered new interface driver brcmfmac
[11044.455098] brcmfmac: brcmf_sdio_bus_rxctl: resumed on timeout
[11044.460935] brcmfmac: brcmf_c_get_clm_name: retrieving revision info failed ( -110)
[11044.460944] brcmfmac: brcmf_c_process_clm_blob: get CLM blob file name failed (-110)
[11044.460951] brcmfmac: brcmf_c_preinit_dcmds: download CLM blob file failed, - 110
[11044.460958] brcmfmac: brcmf_bus_started: failed: -110
[11044.461004] brcmfmac: brcmf_sdio_firmware_callback: dongle is not responding
Edit:
This post (post #25) confirms that TVHeadend may cause the pi too crash which, I am also experiencing!
However, on that pi I am also having problems with wifi in fact I canât even set it up to use wifi via the installer.
I managed to solve the problem running under Raspbian by disabling all but the âsshâ interface and rebooting the pi. How would I achieve the same under OSMC?
What is a âssh interfaceâ?
If you tell us what you did on raspbian we can tell you how to do that on OSMC
The interface allowing you to ssh into the pi! Donât really know why it is listed under interfaces on Raspbian since you only need to put a file on the sd card name âsshâ (no extension) to enable it in the first place.
You havenât really answered the question. Weâre more interested in what you disabled than in how to enable SSH.
So specifically, which services did you disable?
And to be clear here, are you referring to the original problem or the new issue you brought up in post #26?
Yes, the problem in post #26! Well, I disabled the interfaces by going to raspi-config then going to the interfaces section, disabling them. I also read online that the Pi only supports 2.4Ghz whereas my home network is using 5Ghz so I enable the 2.4 option in the modem/router settings.
Iâm struggling to see what you actually disabled.
Ah ok,
Camera
VNC
SPI
I2C
Serial
1-Wire
Remote GPIO
any that I wasnât using cause they could be an extra drain on the power.
