Hi!
I’m trying to use the USTV VOD addon on a fresh install OSMC, but it is not working. Is someone else having problems as well?
I had a look at the log file but could not find anything so far. But just in case I’ve posted the relevant part below.
Thank you very much for your help!
Best regards,
Fo
23:32:30 305.276764 T:1616356336 WARNING: CPythonInvoker(18, /home/osmc/.kodi/addons/plugin.video.ustvvod/addon.py): the python script “/home/osmc/.kodi/addons/plugin.video.ustvvod/addon.py” has left several classes in memory that we couldn’t clean up. The classes include: N9XBMCAddon9xbmcaddon5AddonE,N9XBMCAddon9xbmcaddon5AddonE,N9XBMCAddon9xbmcaddon5AddonE,N9XBMCAddon9xbmcaddon5AddonE,N14PythonBindings30XBMCAddon_xbmc_Player_DirectorE,N9XBMCAddon9xbmcaddon5AddonE
23:32:30 305.304138 T:1956500400 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.ustvvod/?url=“VDKA3392954#lf”&mode=“abcchannel”&sitemode=“play_video”]
23:32:45 320.125031 T:1650050032 ERROR: CPythonInvoker(19, /home/osmc/.kodi/addons/plugin.video.ustvvod/addon.py): failed to run the gc to clean up after running prior to shutting down the Interpreter
23:32:45 320.125793 T:1650050032 WARNING: CPythonInvoker(19, /home/osmc/.kodi/addons/plugin.video.ustvvod/addon.py): the python script “/home/osmc/.kodi/addons/plugin.video.ustvvod/addon.py” has left several classes in memory that we couldn’t clean up. The classes include: N14PythonBindings30XBMCAddon_xbmc_Player_DirectorE,N9XBMCAddon9xbmcaddon5AddonE,N9XBMCAddon9xbmcaddon5AddonE,N9XBMCAddon9xbmcaddon5AddonE,N9XBMCAddon9xbmcaddon5AddonE,N9XBMCAddon9xbmcaddon5AddonE
23:32:45 320.159851 T:1956500400 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.ustvvod/?url=“VDKA3392954#lf”&mode=“abcchannel”&sitemode=“play_video”]
23:33:01 335.894745 T:1956500400 ERROR: Window Translator: Can’t find window settingsprofile
23:33:14 349.012360 T:1650050032 ERROR: CPythonInvoker(20, /home/osmc/.kodi/addons/plugin.video.ustvvod/addon.py): failed to run the gc to clean up after running prior to shutting down the Interpreter
23:33:14 349.012726 T:1650050032 WARNING: CPythonInvoker(20, /home/osmc/.kodi/addons/plugin.video.ustvvod/addon.py): the python script “/home/osmc/.kodi/addons/plugin.video.ustvvod/addon.py” has left several classes in memory that we couldn’t clean up. The classes include: N9XBMCAddon9xbmcaddon5AddonE,N9XBMCAddon9xbmcaddon5AddonE,N14PythonBindings30XBMCAddon_xbmc_Player_DirectorE,N9XBMCAddon9xbmcaddon5AddonE,N9XBMCAddon9xbmcaddon5AddonE,N9XBMCAddon9xbmcaddon5AddonE
23:33:14 349.045776 T:1956500400 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.ustvvod/?url=“VDKA3392954#lf”&mode=“abcchannel”&sitemode=“play_video”]
23:33:48 382.958893 T:1725547504 WARNING: CPythonInvoker(22): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
23:33:53 387.617615 T:1759101936 WARNING: CPythonInvoker(23): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
