I’ve taken my Vero out of storage but can’t find the power pack. I’m in the UK, could someone send me a pic of what it looks like? I know its supposed to be 5V & 2A but if I knew what it looked like it would help me with my search.
If I can’t find it, can it be powered by USB using the microUSB port on it? or is there a device in Argos or Maplin I could buy to power it.
I want to take it on holiday on Monday so mail-order out of the question unfortunately.
Sorry to hear you have misplaced the adapter. I’d be more than happy to get you a new one out in the post if you can’t find it.
The PSU is a Stontronics branded adapter and has a detachable plug head.
The original Vero can only be powered with the barrel jack connector unfortunately.
I don’t have a picture of one at hand unfortunately as I use Vero 4K PSUs on the devices now (they are forwards compatible) and it would be in storage.
I’d love to order a new one, but kind of need it for Monday morning, no way I’d get it in time. Its baffling where its gone, I’ve found one that 5V 1.5A with a barrel connector, but its branded Logitech. I’m sure I need the 2A especially if I want to plug a hard disk into it.
I’ll keep looking thanks, may have to abandon it and fall back to my Pi 1.
Hello, @sam_nazarko, I just did not want to make another topic with about the same subject. A few years ago I bought the Vero 1 and after having it back from storage, it did miss the power supply. I find one with a 2.5 A output but it did not boot though it seems to have power.
Probably I need the original one. How can I get one and can I check the sd card to see if that still contains the Kodi software or is it quit blond from me to check that??
Thanks.
P.S.
See you have a very nice successor in store (good reviews) but for now that does not fit my budget.
