I have just received a new Vero 4K+ box and linked it up to an Optoma HD33 projector. Initially the display was almost unreadible with a pink tinge. On the advice of the supplier I forced RGB output via the display settings. This made it possible to navigate through the menus but the display still has occasional interference and the colours have a strong green / pink bias - white shows as pink for example. Other devices (XBox, Wetec Core etc.) display fine. I have tried different HDMI cables.
Are there any other settings I can try or does this sound like a hardware fault?
I think you contacted us about this via eBay. We’d like to get this solved for you promptly.
Please can you go to My OSMC -> Logs and upload a set of logs so we can learn more about your display.
We’ve had some issues with displays showing a pink screen in the past, particularly with Philips TVs from 2009 which misadvertise their input capabilities.
Done - the updates downloaded and seemed to have been applied successfully. However, the image is now worse - it’s like before applying the force RGB setting. I’ve used the shell to grab the logs: https://paste.osmc.tv/derepapeju as the text is illegible.
Sam - I have just got hold of a HDMI->DVI cable to test the Vero with my PC monitor. When I plugged it in initially the display worked fine. However it then deteriorated rapidly into a green fuzzy mess. I tried a couple of times and then realised that I could switch between perfect and fuzzy by moving the HDMI plug up-and-down slightly at the Vero end. This makes me think the HDMI port is the problem and the log issues may be reflecting a poor signal between the Vero and the display.
