Hi, i just received the new Vero 4k+ and when im playing a 4k/hdr atmos movie via my 2tb usb hdd the sound stutters every couple of minutes. the HDD is formatted to ntfs and i have it connected to the side of vero. Vero is connected to a pioneer av receiver that handles 4k/hdr/atmos etc. any advice would be great.
thank you
Is the drive self powered, or connected via a powered hub?
Logs are always helpful so we can see your configuration settings.
reboot the OSMC device
reproduce the issue
upload the log set either using the
Log Uploader
method within the My OSMC menu in the GUI or thessh
method invoking commandgrab-logs -A
thanks. im new to all this.the HDD is a wd passport, usb powered. i will try and get the logs.
You need to try a powered USB hub. It’s likely that the Vero alone is not providing enough power to the HDD under load.
Did you figure this one out?
Are you having a similar issue? Posting details of any problem you may be having will help in our finding a solution for you. Also, posting logs can help.
Yes, I do, and I have a hunch that it might be due to temperature. Will try and get to uploading some logs at a later point. Should I start a new thread, or just continue it here?
Ideally you should start a new thread as the problem may not be related and it would be good to get @guscya’s issue solved too.
