@sam_nazarko
This morning i tried to play the same mkv file from a usb drive connected to the Vero 4k+.
After several jumps (right key on the remote) during the playback i got micro-stutters when i started to play the film normal again (stop the jumps cause i got to the point of the film i want to start).
I would also have been very surprised, because I did not have the problems with the same file on my VU + Duo2 SAT receiver with installed KODI 16.x App and the network structure has not changed.
@fzinken
I converted an BD ISO to MKV with MakeMKV. It took some time but the result is ok.
I played the UHD MKV File from Kodi Library over the network (You remember I use two powerline adapter between Fritz box and NAS) and there where no problems.
Seems really to be a BD ISO Problem not a problem with my network.
Hope that KODI will come fast. Java Menue will be also supported with KODI 18?
Otherwise i have to connect a BD Drive to my Vero for the Menue Support.
