I am a new Vero 4K+ user and I have a problem. My Vero switches randomly back to 720p, while my TV is a Samsung 50RU7170 4K TV. I searched on the forum for a solution and I already set the allowed resolutions in the system preferences and enabled “Lock HDMI HPD”.
The problem mostly occurs when I turn the TV off and a day later on again. I have to reboot the Vero to be able to set it on a different resolution then 720p.
You would need to upload logs (after you have a drop to 720p) so that the team can see what’s going on.
Do you have Adjust Refresh Rate on Start/Stop? Do you have the GUI on 1080p?
Normally it is best to first try with an empty whitelist and only use the whitelist when everything is working.
reproduce the issue
upload the log set (all configs and logs!) either using the
Thanks for your fast response. Will do that. Do not know when I will be back, since it seems to occur randomly. Tried to reproduce it, but can’t. Will report back, when I catched it in a log file.
