Hi, since I have “upgraded” my 4K to a 4K+ I use the “old” 4K ob my bedroom tv. However I now suffer - infrequent - crashes where “nothing goes” and I have to pull the plug.
I have uploaded the logs under http://paste.osmc.tv/adimupupub.
Maybe you can check, why Kodi (17.6 March update) hangs.
Many thanks
Georg
4K+ with similar settings works perfectly.
Are you able to update to Kodi v18.x?
Kodi 17.x is now end of life and is not supported.
From a quick glance of your logs:
- Your GUI resolution should be 1080p, not 4K (although this won’t cause any crashes)
- There is a database problem
You have problems mounting your NFS shares.
====================== Diskspace =================== qZy25Yas
Filesystem Size Used Avail Use% Mounted on
devtmpfs 757M 0 757M 0% /dev
tmpfs 879M 8.5M 870M 1% /run
/dev/vero-nand/root 14G 4.0G 9.3G 30% /
tmpfs 879M 0 879M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 879M 0 879M 0% /sys/fs/cgroup
/dev/mmcblk1p1 120G 824M 119G 1% /media/82DC-0C1C
You have autofs installed but have lines in /etc/fstab prefixed with a semicolon. I assume this is to comment them out, though I’m not sure that a semicolon is supported.
So are you trying to use autofs or fstab?
Oops sorry, I meant 18.6 (typo).
What is my database problem?
Best regards
Georg
I deletetd the fstab mounts and autofs still works, thanks.
i*ll report if i have further crashes!
Georg
