Running the latest version but this has always been present.
In default Kodi when you stop watching something and afterwards resume again it will automatically display the same subtitles as before (for me the external .srt). With OSMC it will revert back again to the subtitles that are embedded in the MKV instead of the previously used external srt.
With default Kodi, I mean latest Kodi from kodi.tv running on Windows.
Content is on SMB share and using a shared MySQL backend.
Everything is scanned into the library.
In that case, providing debug enabled logs demonstrating the issue may give someone a clue to see where your problem is.
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
It might be helpful if you could provide logs and any relevant information regarding your setup. When I tested it the information was being stored and retrieved from the database.
I think I managed to work out what is going on and it is a bug in Kodi that you would need to report over there. It is not an issue with OSMC. What is going on is that Kodi references the stream by number only in the database so a typical movie with two embeded subs may look like this…
stream 0 (english 1/2)
stream 1 (english SDH 2/2)
and if you then download a sub that changes during playback to…
Once you stop the movie the database stores stream 2 as the one it should reload. but when you start the video again you will see that external are ordered first such that…
stream 0 (downloaded 1/3)
stream 1 (english 2/3)
stream 2 (english SDH 3/3) [active as per db selection]
So if you add external subs the selection will be incorrect on the first playback, but if subs are static then the section should be correct as the database is saving and loading.
So what you are saying is when I start a new movie and download new external subs while playing through to the gui, next time I resume the Subtitle ID in the database does not line up anymore because it is now 1 more.
I’ll test that out, great find!
It is not so much that there is “now one more” but rather the sort order is not consistent (and external should probably always be sorted after embedded).
