Hello there ,
Hi recently bought a vero 4k + , and I already have a shield tv and Apple TV but wanted to explore new horizons .
However , after successfully pluging the box to my tv , I could not get the wifi connection to my Asus router despite I see the wifi network properly ? Each time I type the password I have a message failed connection .
Any ideas why ?
Thx for the help
How many white spots do you get for the signal strength?
Hello, I have four ,
And currently trying to connect only on the 2g network.
For some reason I don’t want to use the 5g.
Logs would help greatlly. (Kodi debug logs not necessary in this case.)
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Hi there,
thank you for the answer,
As I don’t have an internet connection and no sd card… is it possible to copy the log on an USB stick ?
thank you,
seb
Yes – it should be saved to /media automatically.
