After media scan the Vero 4k freeze. When the tv was on, there were green screen, and no remote, or ssh reaction.
Here is my log:
https://paste.osmc.tv/mejejubupi.coffee
You seem to have problems with MySQL; and your library sometimes becomes unavailable. This should be resolved first if possible.
Does it only freeze on Library Scans? Can you reliably reproduce this with a scan every time?
If there’s a bad file, it can sometimes cause Kodi to freeze. The solution is to split the library in to two directories and re-scan. If that succeeds, split the folder with the bad file again in to two folders until you eventually find the problematic file.
I try it, but yesterday update was successful 3 or 4 times. But unfortunetly at night it goes offline again. Maybe it freezee when idle?
I think the connection to your NAS may be dropping
