Hello,
I received my Vero 4K some days ago.
My problem is that the external HDD attached to the USB port is always on, it never turns off.
(Before the Vero 4K I had an ACRyan device and the HDD turned off when it was idle.)
I haven’t found any related setting. The software is up-to-date.
Do you have any idea?
Thanks for your help.
Ps.: It would be a “reasonable” solution if the device could be turned on/off with the remote. But I found in the forums that it is designed as “always on”. I don’t like it but I could live with it - if the HDD would turn off if not used.
