I don’t think the API allows it. That’s the impression I get anyway. There’s a thread on the Infuse site where they said they were looking into it and contacted apple about it but no update since Dec.
Switching HDR from auto to force passthrough made no difference.
I can’t reproduce the issue playing through a Vertex. Mine says ‘HDR’. But I don’t have a Vero running the kernel you are on. You might like to try upgrading from the staging repo to see if that changes things.
Hopefully the issue is now addressed.
Run the following command to add the staging repository: echo 'deb http://apt.osmc.tv buster-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.list
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
I’d also recommend you deactivate the staging repository. You can do so with the following command: sudo rm /etc/apt/sources.list.d/osmc-devel.list.
Something else I’ve noticed. When playing a Blu-ray folder of an HDR10 only movie the LUM is always 1000/0.005 and maxCLL/FALL is always 0/0 but if the folder contains a DV movie then the correct HDR10 values are used.
Can you explain what you mean by a Blu-ray folder? Do you mean a ISO image file? Everything else should have their metadata read properly. I don’t have any Blu-ray images to test.
What does mediainfo say? These are the defaults we send if we can’t find any metadata. Blu-rays are required to have this metadata so if mediainfo can’t find any they must be bad rips.
If mediainfo is giving you sensible values and you are prepared to poke around a bit more, with the latest release candidate (which you have installed) there is more information reported in the Kodi log about HDR metadata. Can you have a look at that and see if it matches what mediainfo says?
Also, if you turn on a bit of extra debugging: echo 1 | sudo tee /sys/module/am_vecm/parameters/debug_csc
you should see the metadata printed out by the kernel in dmesg.
