Hi Dears (from France)
On Vero4K, since a few weeks, my movies library got empty and no possible way to refresh it with present and new movies stocked on external HDD. On the other hand, the library for the TV shows works perfectly OK ! I thought it was a problem with october update and have waited for november update but no improvement ! Any idea of where it could come from ?
Many thanks guys for the god job you’re doing !
Not without logs.
reproduce the issue
upload the log set (all configs and logs!) either using the
Hi Dear,
Thanks for your support, problem is solved now, it was apparently just a problem with my HDD (which works on my PC !!). I have received my new external HDD today and everything seems to be OK !
Many thanks again and best regards
