Hello! The official Vero 4K+ power supply is a little short because my TV mounted a bit high. From what I searched, the power supply is, “5V, 2A center positive, 5.5mm OD, 2.1mm ID.” The following barrel plug extension cable should work, correct? Thanks!
from the photo you posted that cable looks distinctly like the centre negative variety.
Not 100% sure but could cause your media files to play backwards.
It should work but longer cables will cause a small voltage loss which may cause problems. If you are not hanging any other devices off the USB (HDDs or DVB sticks) then you will probably be OK.
Not sure what @geoff_noob is on.
Good to know, thanks! I think Geoff was being facetious about polarity/backwards, lol.
