I know i am behind the curve but just got a Vero 4K+
Have a few questions - I know I chould have asked chat GPT to get answers - but wanted answers from real user experience - I know it end of life but may be the staff posters who i am sure know loads could chip in
Mine is a stop gap till I can aford a V And I Am sure financialy many people will be in the same boat at the min
My fave used be My WD Live Box - This make of box is the only one i have come across that gets close - got an android box then found out - why not to have one -malware etc put it in the bin
I am looking a power use and saving
Am i correct that the unit does not have a power saving mode ?
I have an attached 3TB HD Drive Powered - Is there a way to manage its usage ?
To be honest I dont want the drive spun up and running as the vero is on constantly
Apart from pulling the power plug is there any way to do this ?
I have a spare remote on/off plug will this work corectly if i use this to cut the power than pull the plug
Also I did a full reinstall as was a used unit I tried to get SMB on the device but there were issues obtaining the files for this to work - My helper - Chat gpt know way more about this stuff than i do and we check a few repositories but could not find it - having to use cyberduck to get access from my mac
Is this known and is there a fix ?
Any one help out with this and a reply of “end of life is not going help” if there is an actual answer that may help
oh and is there a maual any place - dont mean the quick start guide - Have not realy used kodi b4 and having a manaul of some sort be a help
If your concern is power usage I would suggest to purchase yourself a power meter like a Kill-A-Watt and perform some tests across your house. I fully understand the want/need/desire to reduce phantom power as much as possible but your looking at a device that has very little to be gained. The Vero itself is going to probably average under 3 watts and with that drive running maybe add another watt or two. Some drives will spin down on their own and some will not, at least not without a bunch of messing around. This is kind of the nature of USB attached spinning rust. In my opinion, it doesn’t really matter much either way with modern drives. It is very likely that drive will actually have a longer life if it isn’t spinning the platters down and when most modern consumer drives are sitting there at idle they tend to draw very little power even with the platter spinning. It isn’t the same as decades ago when a living room setup with a CRT, VCR, and cable box would draw 100 watts+ with everything turned off.
It was more the life of the disk if kept spinning thats what I was more worried about its not an enterprise disk just normal consumer thats had quite a life till now - I know the unit used about 6 quid a year was the above - and if a remote on off would be ok to use etc
There is no consensus that I’m aware of and studies done by Google and Backblaze I believe have not found much of a difference one way or the other. On one hand with the drive spinning 24/7 there is bearing wear from the rotation. On the other hand you have bearing wear from the shock load of the platters spinning up and down. The spinning up and down also adds thermal variability that is higher than a drive that is largely sitting at steady state. The early days of the WD Green drive proved that an extreme level of spin up/down had a major impact in dramatically shortening the drive life. How that communicates to a modern normal spindown timing where you would be looking at 5+ min before a spindown vs those bad WD Greens which waited only something like 5 seconds whos to say. It is pretty clear though that there is not some major issue with a drive spinning continuously as nobody has ever been able to prove that out.
The difference between consumer and enterprise might not be quite what you think it is. They are not necessarily built better, but rather have features like SAS, delayed start control, vibration protection, TLER, etc. It isn’t uncommon for a manufacturer to sell the exact same physical drive for both markets with just a difference in firmware and the motor spinning at a lower RPM.
I use an Alexa controlled smart plug on my Vero and my external hard drive, i just gracefully shut down the Vero first and then i turn off the smart plug, i’m happy with this solution, I wouldn’t just turn off the smart plug without first shutting down the Vero though.
I am a complete nubee to kodi - so quick additional question - is ther a way to stop playing when you exit a folder ? I am used to just exiting a folder on my samsung tv - Its anoying that the player keeps running any sugestion - apart from turn it off first - lol
Are there any Kodi 101 on you tube that people have used and found of help - I am guessing a manual is not that likely ?
And by this do you actually mean when you are playing a video and you hit the back key it stops the video instead of playing in the background? If that is what you meant then the simple solution is to do a slight tweak to the keymap so that button activates stop instead of back. If this is what you wanted just let me know and I can walk you through how to do that. You will need to let me know what type of remote control your using.
Kodi has a wiki, we have a wiki, they are essentially online manuals. Alternatively, you can just do a web search for “kodi” and whatever you want to know and you should find plenty of info from quite a few different forums. I’m sure there probably is some video content out there but I highly doubt that is easier to consume.
Does the box have a output brightness setting - The tv is at our normal setting but this seams very bright - I did find a setting in 25 pc incruments turned down but dont think thats made a diffrence I mean the Menus etc not playback thats ok
Are you referring to just the OSMC skin using lighter colors than your preference? If so if you dig into the settings for the skin you have options to tweak it. Alternatively you can just try other skins to find one closer to your preference. There are quite a few different skins to choose from.
As for @jb2cool’s suggestion regarding the smart plugs, if this is something your interested in I’d suggest to first run a test whereas you tell Kodi to power off and then unplug the power cord from the Vero only. Once you have done this check to see if the hard drive spun itself down. If it did then there would really be no point in controlling its power input as it would be dealing with it on its own.
